Total posts in this thread: 15
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 6014 times and has 14 replies Next Thread
pohlmannfrank
Sweet Home 3D Online Manager
First of all: Really great software! Thanks for that!
I have now installed Sweet Home 3D JS on a lolalem Tomcat. However, there must be a connected user for everything to work. My question is: is the Online Manager also available for download? I'm just hanging here a little because it's not possible to work without saving changes. Or is there a tutorial for this?
Best regards
[Apr 6, 2022, 5:32:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sweet Home 3D Online Manager
No, the default web application proposed with Sweet Home 3D JS is able to record the changes made in a file matching the home parameter sent to index.jsp (see also readHome.jsp). For example:
will edit the file MyHome.sh3d, creating it if it doesn't exist.
But if you don't want to keep all the SH3D files in the same folder and/or prevent the SH3D files of a user from being read by anyone, you'll have to program some authentication system, the reason why I reused the forum login page as a SSO (Single Sign-On) on sweethome3d.com. But you could also start without authentication and use a permanent cookie to name the folder matching a user on the server.
No, because it depends on the forum authentication system and how sweethome3d.com database is organized. I could program also a less specific solution but I prefer to spend some time on Sweet Home 3D improvements now.
[Apr 7, 2022, 11:20:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pohlmannfrank
when I try this I get the following errors in the browser console and the sh3d file does not load:
sweethome3d.min.js:20 GET http://localhost:8081/SweetHome3DJS-7.0/userR...3d-487f-89fc-e0d0039d64b7 404 (Not Found)
RecordedUserPreferences.readPreferences @ sweethome3d.min.js:20
RecordedUserPreferences.getProperties @ sweethome3d.min.js:20
RecordedUserPreferences @ sweethome3d.min.js:20
SweetHome3DJSApplication.getUserPreferences @ sweethome3d.min.js:20
(anonym) @ index.jsp?home=MyHome:1421
sweethome3d.min.js:20 GET http://localhost:8081/SweetHome3DJS-7.0/readH...5f-49b4-9455-7adbca5bca58 500 (Internal Server Error)
ZIPTools.getZIP @ sweethome3d.min.js:20
HomeRecorder.readHome @ sweethome3d.min.js:20
IncrementalHomeRecorder.readHome @ sweethome3d.min.js:20
(anonym) @ index.jsp?home=MyHome:1425
index.jsp?home=MyHome:1437 Error: 500 while requesting http://localhost:8081/SweetHome3DJS-7.0/readH...5f-49b4-9455-7adbca5bca58
at XMLHttpRequest.<anonymous> (sweethome3d.min.js:20:1495409)
die user Resources kann ich sehr wahrscheinlich einfach aus der index.jsp rausnehmen? das sh3d-File kann aber nicht geladen werden. irgendeine idee was ich falsch mache?
[Apr 7, 2022, 1:53:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pohlmannfrank
last sentence above:
I can probably just take the user resources out of the index.jsp? but the sh3d file cannot be loaded. any idea what i'm doing wrong?
[Apr 7, 2022, 1:55:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You'll get the first error as long as you didn't modify preferences, since userPreferences.json file will be created at that moment.
For the second error, it's an HTTP 500 error so you should check logs on server side (there's probably a stack trace in logs/catalina.out file).
[Apr 7, 2022, 4:52:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pohlmannfrank
Thanks, i get the following error:
Apr. 07, 2022 6:38:39 NACHM. org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet [jsp] in context with path [/SweetHome3DJS-7.0] threw exception [Unable to compile class for JSP:
An error occurred at line: [51] in the jsp file: [/readHome.jsp]
Resource specification not allowed here for source level below 1.7
48: }
49:
50: synchronized (homeFile.getAbsolutePath().intern()) {
51: try (InputStream input = new FileInputStream(homeFile);
52: ByteArrayOutputStream output = new ByteArrayOutputStream()) {
53: byte[] buffer = new byte[8096];
54: int size;
An error occurred at line: [67] in the jsp file: [/readHome.jsp]
64:
65: response.setIntHeader("Content-length", homeFileContent.length);
66: response.setHeader("Content-Disposition", "attachment; filename=" + homeFile.getName());
67: try (OutputStream servletOut = response.getOutputStream()) {
68: servletOut.write(homeFileContent);
69: }
70: } %>
Stacktrace:] with root cause
org.apache.jasper.JasperException: Unable to compile class for JSP:
48: }
49:
54: int size;
64:
69: }
70: } %>
Stacktrace:
at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:103)
at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:392)
at org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:594)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:400)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:370)
at org.apache.jasper.compiler.Compiler.compile(Compiler.java:354)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:660)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:400)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:395)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:339)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:492)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:165)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:1025)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1201)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:654)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:319)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
What can i do?
[Apr 7, 2022, 5:41:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You probably run Tomcat with an old Java version. Use at least Java 1.7 or the JDK you used to build the project, since it required Java >= 11.
[Apr 7, 2022, 6:18:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pohlmannfrank
now i have this configuration
Apache Tomcat/7.0.106 17+35-2724 Oracle Corporation Windows 10
but it doesn't work
[Apr 8, 2022, 2:48:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe it's an issue with Tomcat. I never tried with Tomcat 7. Can you try with Tomcat >= 9?
[Edit] Actually, you're not the first to encounter this issue, and I think the solution for Tomcat 7 is described here.
[Edit 2 times, last edit by Puybaret at Apr 8, 2022, 5:12:23 PM]
[Apr 8, 2022, 3:20:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pohlmannfrank
it is now running on Tomcat 9.
Thank you for your patience
[Apr 9, 2022, 4:50:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
