Total posts in this thread: 19
Posts: 19   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 4298 times and has 18 replies Next Thread
shellie222
Re: ZipException: invalid entry CRC on opening the sh3d file
i also removed
.eteks
- no success with either file
sorry for the multiposts
[Apr 6, 2022, 11:57:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
what did you do though?
I just opened it, then I've selected File->Save as.
Are you able to create a new file, save it, and open it back without getting errors?
Maybe you have updated your JDK and the new version has a different/bad zip implementation. You could try to start SH3D pointing to a different JDK.
Anyway, don't worry, your files aren't corrupted :)
[Apr 6, 2022, 12:44:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Wile You are under linux I recommend You to use the official version from this site
(forget the repository versions )
Eventually read this post
After that I'll be able to help You.
Anyway Your file 3UrP maybe need a extension like sh3d or zip or tgz
[Apr 6, 2022, 1:30:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shellie222
Daniels, huh, unexpectedly Im not able to do so - i just tried that twice
I did not update java since I installed sweethome3d - and it flawlessly worked before (opening and saving)
I dont know what could have caused the now permanent misbehaviour - is there some debugging function ?
As said, the repository version can not be the problem here - it worked before (no changes in java/sweethome packages happened).
[Apr 6, 2022, 2:11:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shellie222
i tried openjre8 11 and 17 - all yield the same result
however I can load the demos
[Apr 6, 2022, 2:47:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
This isn't so weird since demos are embedded within the jars, so as long the application starts it will always be able to load the demos.
It could be that the JDKs use some native system call to handle compressed files (but not the jars), so a system update or other software installation could affect the JVM behaviour. Have you update your OS or any other application?
[Apr 6, 2022, 4:33:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shellie222
yes I updated several packages like kernel and libzip
but as I can uncompress the files outside sweethome3d I wouldnt suspect a problem with external packages
explicitly the crc checksum error would have to occur if it was system issue
[Apr 6, 2022, 4:56:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Sorry, but I have to contradict you :)
There are 2 ways a zip can be opened:
- as a file, meaning a determined amount of data, which you can access randomly;
- as a stream, meaning a flow of data which you can read only sequentially.
SH3D uses the latter (ZipInputStream is mentioned in the stacktrace). It is well(?) know that this way of opening zip files may cause problems... I won't report the details here, but you if you are interested you can learn more here: https://commons.apache.org/proper/commons-compress/zip.html
So you may try rollback the libzip upgrade. This isn't a solution, but if we can identify the bug we can find a workaround and possibily fix it in the future. Please also post the version of the libzip you're using.
[Apr 6, 2022, 5:12:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shellie222
I would not have thought that
warning: downgrading package zlib (1:1.2.12-1 => 1:1.2.11-5)
did the trick apparently
[Apr 6, 2022, 6:30:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
