Total posts in this thread: 4
Previous Thread This topic has been viewed 2774 times and has 3 replies Next Thread
otadmin
Default furniture with install
When I download Sweethome3D and run it some default furniture is available. Examples are "Box, Cylinder and Triangle". They do not show up in the Furniture-Editor nor can I find a .sh3f file containing those.
Question: Where are the furniture-items found when SH is run without any .sh3f files?
[Mar 27, 2022, 7:10:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Default furniture with install
The default furniture is stored in the file Furniture.jar found in the lib subfolder of Sweet Home 3D installation folder. If need, you can remove it from there, open it with the Furniture Library Editor and save it in a SH3F file that you'll import in Sweet Home 3D.
Note : the original post mentioned Furniture.zip file not Furniture.jar.
[Edit 1 times, last edit by Puybaret at Mar 28, 2022, 10:02:13 AM]
[Mar 27, 2022, 4:05:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
otadmin
Found and saved as .sh3f. But in both versions 6.4 and 6.6 the file is called furniture.jar. Opens with the editor no problem.
[Mar 28, 2022, 9:16:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Oups, sorry you're right the default furniture is stored in Furniture.jar not Furniture.zip. I should have double checked before answering.
[Mar 28, 2022, 10:00:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
