otadmin
Re: Select furniture file .sh3f
Found that the problem is a little different! On inspection I found that it uses object.sh3f which has a size of 178.3 MB. But it does not show all the furniture nor all the categories in the application, only in the furniture-library-editor. In the meantime I uninstalled all SH from the LM repositories and manually deleted everything with sweethome and related. Downloaded your latest version 6.6 which I run out of the folder and Furniture-Library-Editor-1.28.jar . Opened the file with the new editor and saved it as Furniture.sh3f. In the editor everything shows up. Run Sweethome and not everything is listed. For example I put everything like chairs, sofas etc into a category "Seating". Seating shows but it lists far fewer items than seen in the editor. Let me tell you how much I enjoy your program and I am discovering new features every time I use it. At the moment I am drawing a house from relatives in Panzhihua, China.
[Mar 25, 2022, 3:55:24 AM]
[Link]
