Is It Possible to Reset Dimension Text to a Default Size?
I have several dimensions that I've individually increased and decreased to various sized text, so it's very inconsistent throughout my plan. Is there a way to set dimensions text to a specific size, as can be done with regular text?
Italy
Re: Is It Possible to Reset Dimension Text to a Default Size?
Option 1 Select all dimension lines, hold down CTRL+ALT+SHIFT, then press repeatedly "K" to reduce the text size of all dimension lines up to the minimum value; then hold CTRL+ALT, and press "K" 11 times to increase the size again to the same value for all the dimension lines.
Option 2 Close the program, then open the home file with any zip extractor, edit the Home.xml file with any text editor and change the value of the fontSize attribute for all the dimensionLine>textStyle nodes. Save the file and pack it back into the home file.
[Edit 1 times,
last edit by Daniels118 at Mar 19, 2022, 1:27:40 PM]
