Total posts in this thread: 309
Posts: 309   Pages: 31   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Previous Thread This topic has been viewed 821796 times and has 308 replies Next Thread
GrahamI
Australia
Re: Generate roof plugin
I'm having trouble uploading the Image
[Aug 28, 2022, 3:13:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
I'm glad to see here someone closer of my age (well, also more wiser than me).
Don't expect too much from me.
Let's start:
You've send me this:
If You send the sh3d file maybe could be easier.
Anyway I put it on background and I've try to understand what was in Your intentions
I suppose this could be the base structure.
Hiding the background, remain this:
I use Auto Dimension plugin to generate roof projection. (not mandatory)
The result is this:
It's not quite useful but it's a start
It appear You want to make a house from round wood,
so, You have to adjust the roof projection probably something like this,
by deleting unnecessary points from room
Now, with room selected, Tool->Generate roof...
Well, here are at least two variants:
1. simple hipped roof
Press Ok
Modify texture
2. Something like gabled roof
Select triangle faces and set angle at 90 dg ( or what ever You want)
After press Ok
Set texture...
Select some faces and mark them as invisible
Could be something like this
Of course You could make it better.
Good lack!
[Aug 28, 2022, 7:54:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
Hi Dorin,
Thank you very much for your very prompt reply. It is much appreciated.
I have not given you the full picture, for that I apologize.
I will attach the SH3D file separately. Until I get this finished I would like to keep this private. After that it will be available to TV and ALL in the Public Domain.
Regards Graham
[Aug 29, 2022, 12:52:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
1. I don't know if my explanations was useful (solve the problem);
2. The file would have been useful for more precise help;
At this moment I don't need it anymore.
[Aug 29, 2022, 7:44:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
Yes it's a Log Home, with a lot of work to be done still.
The First floor is to have a Bathroom and 4 more Bedrooms.
Much to be done... 😒
Regards Graham
[Aug 30, 2022, 1:34:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Klaus60
Wanted to start a new attempt to generate the roof but unfortunately without success.
Have the same problem as Graham.
I marked all the walls and carried out the Plugin Auto Dimension.
Now I can't get any further, Generates Roof (3.0) is still grayed?
How can I hide the background?
Sorry for my beginner questions.
Regards Klaus
[Nov 12, 2022, 10:28:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Select generated roof projection (room) or any other room and Generate roof... will became active.
With Autodimensioning yo don't need to select enithing on plan.
Just lunch and chose "Selected walls" and check generate roof projection with noting selected in plan.
[Edit 1 times, last edit by dorin at Nov 12, 2022, 12:11:49 PM]
[Nov 12, 2022, 12:06:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Klaus60
@dorin, first of all, thanks for the answer.
I probably make a mistake, I still don't manage to activate the roof generator.
I did the following:
1. 2nd floor selected
2. All walls marked
3. -> Tools -> Autodimension
4. Roofenerator is still gray ??
Would it be possible to explain the step by step to me?
I hope it is not too much.
Regards Klaus
[Nov 12, 2022, 4:27:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Isn’t this post detailled enough?
[Nov 12, 2022, 5:08:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Klaus60
You are right that is very detailed, I just stand too stupid to generate a roof. The roof generator is gray and I don't know what I'm doing wrong ??
[Nov 12, 2022, 6:18:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
