Total posts in this thread: 313
Posts: 313   Pages: 32   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Previous Thread This topic has been viewed 839157 times and has 312 replies Next Thread
dorin
Romania
Re: Generate roof plugin
News (no breaking)!
In the last several months I've made some kind of team with Daniels118.
That's mean I make a wish and he make it real.
Then I make it public like it is my work. In fact that's all my effort.
Anyway, it was a heavy time consuming and a lot of try and fail, than start from the beginning.
Finally new version 3.0 !
What's new (not to mach):
1. Individual face selection with mouse (thanks to Emmanuel & Daniele),
2. Individual face angle set (thanks to Daniele),
3. Add a Help button with some useful information (I've stole some codes from Daniele).
-Add Chinese translation (thanks to YGYL but incomplete at that moment, need updated).
As You could see I have nothing to do with this version.
Some screenshots and explanations (for new comings):
- Start from a selected room as roof projection (generated by Auto Dimensioning plugin or manually drawn)
- Tools->Generate roof
- You will see something like this
- Select a face with mouse
- Rotate roof and select other face.
- Press Ctrl+click on other face
- Click elsewhere to deselect all, select a face, then Ctrl+Click to select desired faces.
- With this selected faces modify faces angle with the slider.
- Make the same with other faces
- Click Ok to export roof on home
- Open in Modify furniture -> Modify materials
Select all faces and set the desire texture
- Select some specific faces and mark as invisible. Ok.
- That could be the result
Also on Source Forge
[Aug 8, 2022, 7:31:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hello Team Dorin,
Thank you very much for this new version. It works, more or less.
I followed the steps in Dorin's message, and this is what happens:
- the plugin generates a correct roof
- the new interface appears with the angle slider
- however, the list with roof sections is not visible, and
- I cannot select individual roof parts in the 3D preview
- after clicking OK I try to apply textures
- when I select Modify Roof, I can apply textures to each individual roof section
Maybe you published version 2.9 instead of v3.0 ??
[Aug 8, 2022, 8:15:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Hi Hans,
the angle slider was already there in the previous version (2.5), the version 3 adds the faces list and the help button. If you click the help button you will see the current version. Also note that this version requires SH3D 7.0 or later.
Please be sure you have installed the latest version and don't forget to restart SH3D to let the changes to take effect.
If you have done the steps above and still experience problems, please post a screenshot of the GUI.
[Aug 8, 2022, 10:15:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It seems the plug-in doesn't replace the previous version, or maybe I did something wrong.
Seems to work like it should now, but I will test more in the coming days.
Once again, many thanks to Team Dorin :-)
[Aug 8, 2022, 11:05:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
Does anyone have some samples of how to use this Plugin ?
Regards Graham
[Aug 23, 2022, 2:36:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you look at the previous messages? Just try to reproduce some similar rooms.
[Aug 23, 2022, 3:29:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
confused Re: Generate roof plugin
Hi Dorin,
I have a rectangular Roof and the Roof loads with the 2 Sides and the 2 Ends at 45°. I would like to change the angle of the 2 Ends to be a different angle. How can I achieve that please?
Regards Graham sad
[Aug 25, 2022, 6:12:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
Hi Dorin,
Please ignore my earlier message. I have now read your earlier message with illustrations and I believe the answer is in there.
Regards Graham
[Aug 25, 2022, 7:37:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
sad Re: Generate roof plugin
Hi Dorin,
Despite all attempts I am unable to Use your Plugin to create my Roof. I hope you will help me here ....
I'm wanting a 5m wide roof at the Northern end, running East/West and then 3 Ridges running North/South with an East/West wing over the Port Couchere in the South.
Can you help me with GenRoof please?
Regards Graham
[Aug 28, 2022, 3:06:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GrahamI
Australia
I'm having trouble uploading the Image
[Aug 28, 2022, 3:13:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
