Total posts in this thread: 339
Posts: 339   Pages: 34   [ Previous Page | 25 26 27 28 29 30 31 32 33 34 ]
Previous Thread This topic has been viewed 3080666 times and has 338 replies Next Thread
Re: Generate roof plugin
And, If don't matter, I'll tell you what would make it perfect (I've just try):
If square or even round holes could be opened in parts of the roof.
I don't know about round holes but Dorin created the possibility to add special windows into the roof. Indeed one of the very best plugins!
Check this post and the latest versions on sourceforge .
[Nov 17, 2025, 2:12:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
You need both hands to write code faster! No need to give away body parts, just time to learn and try.
You can obtain rectangular holes using the roof window library. Then if you need just the hole for a stair, you can make the window invisible.
[Nov 17, 2025, 4:10:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Welcome aboard!
While you're already here don't hurt to read the entire tread from start. I have written several user manuals (outdated) but still valid.
0. All the awards have to go to Daniels118 and Emmanuel.
I know absolutely nothing about programming.
I'm not either.
1. Keep your hand and fingers safe; you will need them.
2. Be carefully, a dream could easy became a nightmare.
The last version is a nightmare for me and I'm a nightmare for Daniels118.
3. Nothing is perfect! (Not even God, look at the world created in seven days).
I've never tried round holes but half round. (See this post )
or Roof dormers tutorial .
If you need help just ask.
[Edit 1 times, last edit by dorin at Nov 18, 2025, 6:48:07 AM]
[Nov 17, 2025, 8:52:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
"A small step for the plugin, a big step for me."
I've manage to make SitePlane to work with java3D.
Now I need to learn how and why it works.
Then, how to use it for the existing plugin without breaking it.
[Feb 25, 2026, 8:12:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Version 5.2
News:
- Correcting the elevation of roof windows when the height of the roof has been previously modified in the plan.
- Replace the invisible checkbox function with the corresponding closed eye for each face in the list.
- Add a right-click context menu to the list of faces.
- Rewrite the Axes class. Now they automatically adapt to the roof and are 1 m longer.
- Add support for grouped roof windows.
Also on Source Forge .
[Mar 6, 2026, 11:20:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Xlance
Can we use the new Boolean plugin to subtract holes in generated roofs ? Consequently adding any window from standard library.
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
[Mar 11, 2026, 7:28:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You can do that now. But...
The resulting roof will no longer have separate material names and it can't be re-imported in the Roof Generator. You will have to repeat the boolean difference operation for each window.
That said, the calculation behind the boolean difference option could possibly be integrated in the Roof Generator plugin and create the holes without changing the rest of the roof. I don't know if this is possible. Dorin will know more about that since he knows both plugins.
Using regular windows is problematic in itself: you can't tilt regular windows. You will have to export them, import as normal furniture, tilt, export, and import again as door-or-window. Extra library properties like sashes and wall distance will be lost and opening the windows could be affected too. Regular windows are not what you usually see in sloped roof.
What would be absolute perfect is if the roof could act like a wall where a window snaps into the roof like it does in a wall. Makes it real easy to add windows and change its position. No need to cut a hole before placing the window.
[Mar 11, 2026, 8:46:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
@Xlance
Keet is correct. You will lose all the properties specific to roof and window objects.
On the other hand, the MBC plugin is far from acceptable, mainly because of the texture, but also because some results have missing facets.
@Keet
To install roof windows in a roof, you still don't need to make holes; they make their own. I explained this in the user manual.
[Mar 12, 2026, 8:17:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
