Total posts in this thread: 309
Posts: 309   Pages: 31   [ Previous Page | 13 14 15 16 17 18 19 20 21 22 | Next Page ]
Previous Thread This topic has been viewed 817191 times and has 308 replies Next Thread
Re: Generate roof plugin
@Daniels118 You've right!
I've replaced with null and it works.
Will be available on next version.
You guys are great! Thank you for the fast response. I'm waiting for the next update!
I'll copy the solution to the Staircase generator thread where I raised the same problem.
[Mar 12, 2023, 11:21:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
socrate_54
Hello,
Thank you for your quick answer.
I'll try after some garden stuf to do in early spring.
stuf=(spread fertiliser)
Regards
[Mar 12, 2023, 12:53:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
socrate_54
Hello,
i surely miss something, The roof is well done and the hole for the window is at the right place but the window is still vertical.
So i need some help.
I often don't use forum, so i don't know how to put a picture on it.
Regards.
[Mar 13, 2023, 11:42:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
...but the window is still vertical...
Your window is probably still typed "Door or window" which means you can't tilt the window.
Set the depth of the window to the thickness of the roof you created. Export the window and re-import it but don't check the 'Door or Window' property. You now have your window back which you can tilt but it won't create a hole in a wall. No problem since you want to insert it into the roof, not a wall.
You will have to tilt the window to the same degree as you have the sloping of your roof part where the window is to be placed and you will have to set the position and elevation to fit it right into the hole in the roof.
If the window had options for deformation ('opening the window') this will be preserved and should still work, even when tilted.
[Mar 13, 2023, 1:56:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
socrate_54
Tank you vert much, that works
[Mar 13, 2023, 6:23:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mutajlako
Bulgaria
Hello, can someone help how to show Generate roof in Tools ? I download and install Generate roof 4 (see it in plugins) but in tools i only see Copy as new furniture ? :/
[Apr 8, 2023, 10:46:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Try with SH3D > 7.0 installer version.
Last is 7.1 from here .
[Apr 9, 2023, 9:43:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harryth
Germany
Hello Dorin,
first of all a big thank you for providing this plugin. It will save a lot of time compared to designing a roof with external tools and import it to SH3D.
I am struggling with creating a hole in a roof. You showed in this thread how it should work.
You gave a hint to have not a square hole but a 5 corner hole. If I do it like this, it works.
But if I want to have a square hole it looks like this
and if I try to make the side areas to 90° I get this:
Can you give me a hint what I am doing wrong here?
Thanks in Advance
Best Regards
Harald
[Apr 20, 2023, 4:18:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Hi Harald,
Nothing wrong, just read my first signature.
The Weighted Straight Skeleton algorithm compute holes in the roof projection NOT in the roof face.
Accordingly to the hint, the difference for the extra point could be less than 1 cm which, in real world of the house constructors, it's not a big deal.
Probably you want something like this:
The plugin interface:
Probably you (and others users) have to wait.
If all roll normally this will be a gift for this Christmas.
It's a work in progress (a lot of work sad ) and noting push as (GRT) to be hurry!
[Edit 1 times, last edit by dorin at Apr 21, 2023, 8:19:44 AM]
[Apr 21, 2023, 8:18:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Wow, that looks very promising!
While you're at it, try to make the border textures to follow the roof line wink Or even better a selectable texture for each border so you can differ between the horizontal sides and the sloping sides.
Many thanks for the immens effort you are putting into this excellent plugin!
[Apr 21, 2023, 9:24:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
