Total posts in this thread: 284
Posts: 284   Pages: 29   [ Previous Page | 20 21 22 23 24 25 26 27 28 29 ]
Previous Thread This topic has been viewed 787834 times and has 283 replies Next Thread
dorin
Romania
Re: Generate roof plugin
1. Thanks for your willing to help.
2. Don't forget: there is all kind of irregular 3D polygons so I need an universal formula (preferably some java code)
3. The bad news: I've put in hold this plugin for around 8 months. I continue to fight with Stair Builder.
4. The good news: I'll think about this along the others when I'll have time.
[Jan 2, 2025, 6:01:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
k005
TURKEY
Yes you are right. There must be a universal formula.
Of course, when you have time. Thank you for developing and sharing such a plugin.
[Jan 2, 2025, 6:23:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
k005
TURKEY
Maybe it will help you find it...
In this code, the area of ​​each triangular surface of the 3D surface is calculated by Heron's formula.
This formula helps you find the area of ​​the surface with the side lengths of the given triangle.
Heron's Formula:
If the side lengths of a triangle are aa, bb and cc, the area AA is calculated as follows:
Here, ss is the half perimeter of the triangle and is calculated as follows:
[Jan 3, 2025, 5:24:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Thanks! Could be useful BUT...
I need to input a 3D series of points (x.y.z) representing the irregular polygon boundary (supposing all points belongs to the same plane)
and something(formula or code, eventually java code) to compute the 3D polygon area.
So, please continue searching.
[Jan 3, 2025, 5:52:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
