Finland
An arch roof
Hello.
Newbie asks that how I do an arch roof to a room? Like cave ceiling? We have some 3m width room and according to test (as a normal wall) arch extent is 118 degrees. In other words the arc is bent some 80 cm. Rgs, TM007
Re: An arch roof
- Draw a wall of the length needed (3 mtr) - Use Modify walls - Arc extent and set it to 118 degrees - Apply texture(s) on inside and/or outside (rotate 90 degrees if needed) - Export selection - Import and rotate 90 degrees
Finland
Re: An arch roof
Hello hansmex. Thanks about guiding. I followed maybe wrong Your instructions because I couldn't "flip" the arch to top of the room. I try harder. Anyway nice to know that it is easy to make own library elements! Nice feature.
