Total posts in this thread: 15
Posts: 15   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 26090 times and has 14 replies Next Thread
Re: Convert to Autocad or DWG or DXF
(Of course, a person who is conversant in Autocad will not want to install SH3D.)
I've read here in the form multiple times where SH3D is used next to Autocad to visualize designs for clients so this is an unfounded remark.
Concerning your format conversion problem: try to use freeCad to import an obj export from SH3D and save it as DXF. I have no idea how well that works but it's worth a try. You might have to do this in parts.
You can also try one of the many online converters but in my experience they don't work too well with full plan exports.
[Jan 16, 2023, 8:00:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Maybe you have to read this
For me it work between me and other coworkers with AutoCAD or ArchiCAD.
They don't need to install nothing. I send them only the dxf file.
[Jan 16, 2023, 1:50:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rolinger
Bosna i Hercegovina
I'll revive the thread since I have a specific workflow that produces extremely good results:
In order to obtain an accurate cross-section or even a floor plan, the following steps must be taken:
1. Export the complete model in *.obj format
2. Import the model into Blender
3. Export the model in DAE format from Blender
4. Load the DAE model into Sketchup
5. Scale the model to obtain the appropriate scale of the model
6. Use Tools->Section plane and set the section plane to the appropriate position
7. Select "section plane" with the right button and select "Create group from section plane"
8. The group of elements created in this way can be moved to appropriate places outside the model and in this way more groups or cross sections can be made
9. Select the groups formed in this way and use the plugin "Export to dxf or dwg"
I use SketchUp Make 2016 for this purpose and things work perfectly.
However, I secretly hope that Puybaret will make a plugin that will enable this procedure directly in SH3D ;-)
Best regards
[May 16, 2023, 9:41:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Dweinn
Intriguing exchange on design file conversions here! If anyone's seeking a less circuitous route, the Vector Converter on Converter365 could be your saviour. It swiftly turns your SH3D exports into DXF without any software juggling - maintaining quality while saving you time. Try turning your design dreams into DXF realities in just a few clicks with this "vector converter ". Less hassle, more design power at your fingertips!
[Jul 25, 2023, 12:49:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Xlance
from sweethome3d to autocad
saveas .svg > open in inkscape > saveas.dxf or .dxf v12
https://mydxf.blogspot.com/2008/11/inkscape-r12-dxf.html?m=1
_________
from autocad to sweethome3d
load cad2walls.lsp inside autocad > export as cad2walls.input.txt >
use cad2walls.jar > saveas cad2walls.output.sh3d
https://sourceforge.net/p/sweethome3d/plug-ins/56/
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
[Apr 20, 2025, 1:34:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
