Hello, I'm going to try to create a plugin. I want to have an option for 3D view to have a Stroke or Outline just like sketch up. Any ideas on this? I have a background on Programming. I just need some tips and I'll handle the rest =D thank you very much
Romania
Re: 3D View with Outline or Stroke just like SketchUp
Hi and welcome on board! I don't know whats the purpose of your plugin is or how sketchup work but for this kind of task I use walls in place of stroke. I use this for my Roof generator plugin (very far to be usable). PROS: If you intend to make it open source I'm available to help. CONS: I'm not a programmer.
Hello, I'm sorry for the late reply because I can't find this post. I found it in my profile. Anyway I wanted like this just like the Thread sir hansmex has given me.
But the problem is it can't be added in a plugin and it's heavy in resource just sir ziolink32 said in that thread and it can only be used when you change the source code of Sweet Home.
@sir Dorin. I need it because I will use it in anime/webcomis because the 3D Photo created in Sweet Home 3D has no Lines so I needed to trace the edges.
What I wanted to accomplish is when I create photo in 3D View, it will automatically draw lines or outlines so that it will look like 2D Drawings.
You don't need to recompile the program, just read the end of thread #1472.
Hello I got it now and It's working using his method but it's only
this.drawingMode = DrawingMode.OUTLINE;
is there a way where I can use this.drawingMode = DrawingMode.FILL_AND_OUTLINE; ?
here's the command line that's working for DrawingMode.OUTLINE java -Dcom.eteks.sweethome3d.j3d.drawingModeEnabled=true -jar ./Desktop/dev-files/SweetHome3D-6.6.jar
Hello I managed to do what he instructed in the end of thread#1472. Thank you very much to all of you for replying. Although it didn't do what I want to accomplish but I'm still thankful. This is a good reference for me. Thanks =)
drawingMode='OUTLINE' changed to drawingMode='FILL_AND_OUTLINE' in the XML
