Total posts in this thread: 15
Posts: 15   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 21699 times and has 14 replies Next Thread
zerogravity90
Re: can i install "sweet Home 3d" on my server?
You only need a HTTP server like Apache. But you can also use Tomcat, since it handles also requests to static content.
First, download source code of the latest version.
Then, from the README.TXT file it contains, you'll have to:
- download and install last JDK 6,
- download and install Ant,
- run the following Java command in the directory where you uncompressed the archive of the source code:
keytool -genkey -keystore keys.keytool -alias SweetHome3D
(keytool is a command of the JDK, if system doesn't recognize keytool, give the full path of keytool or change system PATH)
- run "ant" command in the directory where you uncompressed the archive of the source code. The default javaWebStart target will create signed jars in deploy/lib subdirectory.
- edit deploy/SweetHome3D.jnlp file and change the value of the codebase attribute at line 3 to the URL base where you want to host your version of Sweet Home 3D.
- upload the content of deploy directory on your server in a directory matching this URL base.
Your Java Web Start version of Sweet Home 3D is ready. biggrin
Any one can help me?
I create keytool to keys.keytool. but when i run command "ant applet" so system required file keys.p12 . How can i do correctly?
Thank you!
[Apr 22, 2016, 11:12:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please, read the README.TXT file closely.
[Apr 22, 2016, 10:16:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zerogravity90
Thanks a lot Puybaret
I created p12 file successfully and putted it in SweetHome3D directory.
I changed base code to current server too.
I runned "ant applet" command on the next step.
But when i started applet, the Publisher name was being still "UNKNOWN" . What wrong in my steps?
Must I import certificate key (p12 file) into client certificate System? I don't want to do that.
Thank you!
[Apr 25, 2016, 2:47:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It will remain like this as long as you don't acquire a real certificate.
[Apr 25, 2016, 10:02:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
zerogravity90
When i changed jnlp file successful, i got this message when start applet :
java.lang.NullPointerException
at sun.plugin2.applet.JNLP2Manager.initialize(Unknown Source)
at sun.plugin2.main.client.PluginMain.initManager(Unknown Source)
at sun.plugin2.main.client.PluginMain.access$200(Unknown Source)
at sun.plugin2.main.client.PluginMain$2.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Error while initializing manager: java.lang.NullPointerException, bail out
Please help me. Thank a lot!
[Apr 25, 2016, 10:14:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
