Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 75678 times and has 51 replies Next Thread
Re: A Better Render
Please could you do a screenshot of the settings you used?
Of course :
I also did some small changes to your models.
You can find the modified project file HERE
[Jun 15, 2021, 10:16:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Re: A Better Render
Hi Cecilia,
Thank you so much for doing this I really appreciate it.
I just rendered it myself and it looks great. Will these settings work every time?
I'd be interested to know how you changed the models?
Many thanks, Stef
[Jun 15, 2021, 11:02:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A Better Render
When you open the project file I linked to, you can see what I have done if you open Modify on your models:
All the edge color instances have been set to Invisible. Sketchup models are a bit messy and need to be cleaned.
My settings are quite universal, and will often render a nice image.
If you open Modify 3D view , you will see that I have added a white solid texture to the sky.
When selecting Enable sky lighting , you actually enable the sky to act as a source for image based lighting (IBL).
You could have a look at THIS THREAD if you want to read more about IBL.
You might also find some useful discussions and examples HERE.
Cecilia
[Jun 15, 2021, 6:45:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Re: A Better Render
Hi Cecilia,
I can see what you've done with the models.
I tried the same settings on another project and once again I have some weird shading on the Data Racks - See image (what would cause this)?
https://www.dropbox.com/s/tnzv7aiba4nvr7j/IBM_Data%20Centre%20-%20SRS.png?dl=0
I created a white PNG 1000px x 1000px which I used for the floor and the sky but not sure if that's correct or the right size?
I have included the link to the project below.
https://www.dropbox.com/s/dqzt7l7lzylp4cb/IBM_Data%20Centre%20-%20SRS.sh3d?dl=0
Sorry to keep asking all these questions and thank you so much for your help on this.
Stef
[Jun 15, 2021, 11:42:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A Better Render
I will have a look at it to night.
[Jun 16, 2021, 9:04:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A Better Render
As said before, these weird images are because of back faces in DAE / Collada files.
Hide their material as you did for edges.
[Jun 16, 2021, 10:29:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Re: A Better Render
If I make the back invisible nothing happens and if I make the front invisible then the detail disappears totally.
https://www.dropbox.com/s/fzxxpr6d2oonst0/Image1.png?dl=0
How is doing this supposed to make any difference?
[Jun 16, 2021, 10:52:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A Better Render
Hiding the back faces won't show any difference in the 3D view or at the two lowest quality levels.
[Jun 16, 2021, 12:03:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Re: A Better Render
I'm using level 4 and the YafaRay rendering engine as per Cecilia's recommendation.
There is obviously something else I'm missing?
[Jun 16, 2021, 12:45:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A Better Render
The image you posted in your previous message shows the 3D view not a rendered image.
[Jun 16, 2021, 1:08:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
