Canada
I created and imported a trapezoidal window. How do I create wall hatch for it?
I don't understand why if I add a window from the SH3D built in furniture library, I can insert it in a wall and I don't need a hatch, but if I create my own window, I need a hatch. Guess what... if I have a non conventional (trapezoidal) window, there is no way to find a trapezoidal hatch for it. I am stuck... please help
Guys I really like this application but it lacks some basic features. Any idea?
Re: I created and imported a trapezoidal window. How do I create wall hatch for it?
When you import a model that you want to use as for our window, you need to check the box door-window. Read the user guide...
Be sure that the wall where you placed the window has a null arc extent because Sweet Home 3D isn’t able to compute not rectangular shapes in round walls until now. Would it be your case?
I just checked on my side with a similar hole in a wall and it worked with no problem. Share you window model, it might be handy to understand your issue.
---------------------------------------- TrapezeWindow.sh3d
(8492 bytes)
(Download count: 6691)
The front face of your model is its border which is rectangular. Rotating it 90° in the second step of the Furniture import wizard will fix your issue.
