Re: Side view plug-in
Another workaround could be to split the walls, setting the separation of walls in front of the camera.
I've worked in IT all my life, and we have a saying that Excel is the wrong tool for every job, because it is so often misused for doing the strangest of tasks. It seems you have decided to embrace Excel and make it the only tool for every job!
Seriously, I can't imagine trying to do plans in Excel My brain hurts even thinking about it. Bitmap graphics in GIMP or Krita, vector graphics in Inkscape. Excel?... it's like using a chainsaw to trim your nose hair. It might get the job done, but it'll be a bloody mess.
As you are retired and abusing a very old version of Excel, is it fair to say that you are reluctant to learn new software? At the end of the day, use what works for you, but...
I do have to put my IT lecturing hat on for a moment though, and wag my finger at using such old, outdated applications (and possibly operating system). General support for Office 2007 ended in 2012. That is a more than a decade of potential exposure with zero security updates.
If you insist on using a spreadsheet tool to create plans, perhaps look into the free LibreOffice suite of applications. It will install on Windows, and it operates much like Excel. More importantly, you can keep it up to date at no cost, minimizing your risks. And yes... you can draw into the spreadsheet there too.
Looking again at the image you posted, you are using either Windows Vista or Windows 7. Both also at least a decade out of support. And you are on the internet. You are playing Russian Roulette. I really, really hope you do not use that machine for anything even remotely sensitive.
United Kingdom
Excel is a fantastic tool for many jobs - even to create perfectly adequate planning permission plans/elevations (example image attached). Many people reach, first, for the tools they're familiar with.
You mustn't have read what I wrote earlier in this discussion, here it is again:
After having produced reasonable external planning elevations in Excel it became apparent (a bit too late) just how horrendously complicated the task of producing a series of vertical sections within Excel would be.
You could try it someday. As you can see from my image, basic plans/elevations are not enough to hurt most brains. After that it does though.
I hope you are not referring to my image - the local planning officer said they are the basis for an entirely adequate application. Out of a little interest, Excel 2016 included support insertion/editing of SVG so I may splash out on a copy
I've spent that last few days taking a relatively deep dive into Sweet Home 3D.
That was enjoyable - Sweet Home 3D is currently purring along on this Intel(R) Core(TM)i5-3320M CPU @2.60GHZ 4GB RAM and Win7 pro is, pretty much, solid as a rock.
If you imagine M_S is not harvesting all that ou_tloo_kdo_tcom info for, godonlyknows what, well... in any case, I haven't, er, wasted, a penny on a new machine for 11 years. Some heavy duty photogrammetry calculations could cause me to update somewhat if I ever choose to look into that fascinating topic more thoroughly but, equally, if that was the case I might just look into M_S Azure (or similar) in a bit more detail and rent out a host of remote CPU's for as short a time as possible
As it is, i'd prefer to get everything done in Sweet Home 3D but suspect that will not happen. I'd also like not to have to put the effort into learning FREECAD (which I imagine could do it all) but, if possible, do not wish to expend the energy to do that.
So, if sucking a few bitmaps out of here into the old familiar (Excel) for a bit of finishing work/tidy up gets the job done, let's see.
Appreciate that (I hope I don't need to though).
That somehow reminds me, out of a little interest, FREECAD has a very interesting/useful Spreadsheet Workbench.
We all are - TCP/IP encapsulation (and/or whatever follows) makes that so. I'm amazed everytime I login to online banking and there's still a positive balance.
In summary - that "Excel is the wrong tool for every job" is patently untrue. I've used it to great effect over several decades even though the last version of VB / VBA was released in March 2017.
All of what you said was very enjoyable though - so thanks for the comment(s)
I wasn't insulting the end result, more pointing out that it will be painful. A simple example... In Excel you have all your drawn elements on the top of the spreadsheet as just one big collection of drawn objects. Let's take Inkscape as an example: it lets you use layers for separating the objects of your drawing logical groupings, or maybe variations while working out options. Similar to how the levels in SH3D can be used to do the same thing. This is more about working with your plan, not the final output. Your screenshot looks good, but I suspect that is more down to your perseverance then Excels abilities as a technical drawing tool.
Cool! It is awesome for helping firm up how you will arrange the layout and spaces in a building. It's good for representative images, and the plans are good too. Getting elevations is a bit more challenging, especially if you want them dimensioned. Getting them all onto a standard A2 at proper 1:50 scale with a proper info block is a lot more work and requires other software.
This is not about the relative power of your PC, or Microsoft having God mode on your PC. This is about old unsupported software having unpatched vulnerabilities that malicious 3rd parties can exploit. They want three things from you:
your money,
your personal info (that they can sell for money)
your internet (that they can use to attack other systems for even more money)
On an application difficulty rating of 1-10 with SH3D being a 3 or 4, FreeCAD I'd put at a 10. Learning to use it to create final plans would be a huge time sink. But then, you are retired
You must have one of these
Granted, it is a bit of hyperbole, but I've seen people use Excel for managing a large project instead of MS Project when they already had access to the real thing! As dates moved they would sit in meetings painstakingly colouring in the cells of their gantt chart styled spreadsheet as everyone else waited... And don't get me started on "critical" business processes being coded up in Excel and saved on that one "computer genius" persons local hard drive...
United Kingdom
My previous Excel elevation has several "groups". Unsophisticated but perfectly straightforward to achieve, relatively, useful results relatively quickly. The previous image gable wall elevation darker brick portion being built from a single (rectangular) brick/copied twice / both selected / copied twice etc to form a single course. The course grouped / copied x 10. This copied x 2 and a wall is constructed in a minute or two. Layer management (of these groups) is also unsophisticated via Excel "send to front/send forward/send to back/send backward" but for a, relatively, small number of layers it is fairly straightforward to manage (while the "select objects" menu item and a little VBA permits identification of hidden objects in a straightforward fashion also).
By the way, if you draw on a worksheet and print - the output scale is distorted. You must print from a chartsheet to maintain that not to mention that a print size must be chosen before the dimension property of the chartsheet can be set to the desired size (A3/A2 etc)
It is a lot of overhead compared to Sweet Home 3D but familiarity, of course, breeds speed
Cheers
I haven't looked into it in any detail but it seems that VBA can be used to produce relatively sophisticated results (see commercial "Excel Draw" for example)
This is an Excel A3 chartsheet draft pdf used as the basis for a building notice application a few months ago - I hope you like that too? https://i.postimg.cc/DyQmHwZ4/A3-Excel.png
your money,
If we think we are ahead in the evening it'll be reversed by the next morning - for the foreseeable I will, nervously, rely on scheduled AOMEI disc image backup and 2 step authentication everywhere else.
From my pespective, this is not the place to have further discussion on who is the bigger thief (Big IT/Small crook).
Hence my current Sweet Home 3D focus.
Yes, but the real goal must be success in the physical project
With upcoming Global CBDC implementations you'll have something dissimilar too (or starve)
A reminder here of that last migration project from an MM3000 to SAP ERP. Thanks for reminding me just how happy I am to be out of that "rat race"
United States
Hello! I've downloaded all the plug-ins except the Furniture Library Editor. My Mac will not let me open it because it is from an "unidentified developer".
Do I need this to be able to see and edit my dimensions in 3D? I can add a couple dimensions, but cannot move or edit them in any way. And when I use the Side View tool, the dimensions do not show up. I've tried to follow all these threads closely and do as they instruct.
Also, I am unable to save the Side View image to my hard drive. I would only be able to create a screenshot of the view window.
What am I missing? Does it come down to the furniture plug-in? Thank you for your advice.
The Furniture Library Editor is not a plugin but a separate application. The Texture Library Editor is also a separate application.
United States
So the Furniture Library Editor has nothing to do with why my dimensions are not working in 3D nor showing up in side view? I'm curious with what is missing that these functions are not working.
