There is this too: https://touchterrain.geol.iastate.edu/ It allows to export to OBJ format, but SH3D fails to open it, maybe it's just matter of adjusting some lines in the file (missing material?).
Re: Terrain Generator plug-in
No, you have to fix the number format but there seems to something else wrong too. I haven't figured it out yet.
Edit: Correction, just remove all comma's and you can import it in Sweet Home 3D. I don't remember where I encountered the wrong number format.
[Edit 1 times,
last edit by Keet at Aug 24, 2023, 5:01:43 PM]
Concerning a terrain created with touchterrain: Sweet Home 3D doesn't allow a size beyond 100000cm (1km). For a sizable terrain that is of course insufficient but there is a trick to circumvent this: After import save and close the project. Now edit the Home.xml file where you can increase the size. I managed to get a terrain of 100kmx100km by increasing every size of the terrain object.
> The 3Dview might have a few problems (black background when you zoom out). > Export and import from Sweet Home 3D will reduce the obj file size significantly without loosing the increased size. > Strangely, that same export/import increases the reported model size in Sweet Home 3D > The 2Dview becomes a little useless because you can't zoom out far enough to see the whole terrain after you increased the size. > Resizing will make parts a little blocky so first import the model in blender to smooth it. > If you need a terrain just a little over the 1km limit this method is very useful. Maybe up to 5kmx5km.
I abandoned this type of terrain because I don't necessarily need the terrain in Sweet Home 3D itself. I'm investigating html terrains as used in web-games and will try to add multiple Sweet Home 3D projects to that terrain.
I am trying to replicate my home property to plan out my home modifications. Honestly, this idea worked great. Replicated the slope and direction perfect. My land drops 16' over 200' (front to back). I look down on the top of my RV from the road, it is that drastic. Doing this any other way was a pain in the backside.
The obj/mtl export imports perfectly in Sweet Home 3D although it's very small when imported. Just increase its size a thousand times for a great terrain. It also has options for water and sky. And most amazingly it includes a good manual! Available for Linux, Windows, OSX. (And C#/Unity source code is also available.)
[Edit 1 times,
last edit by Keet at Feb 28, 2024, 8:08:30 AM]
where the terrain will be shown higher than it should be
I bet the difference is the thickness of the floor. Read the manual "Levels explained" which you can find on the manuals section on dodecagon.nl. This will explain the relation between level height and floor thickness. Understand that a generated terrain is an object, the same as any other piece of furniture. Which also means you can not 'elevate' it downwards (negative elevation). You can place it on a lower level and elevate it to the elevation you need. This (very old) tip&trick explains creating a pool but it also reveals how to work on a lower level without a floor above it.
