Dimensions - make text movable
Sometimes when you have several dimensions close to each other, the text (i.e. the numbers) touch or overlap each other.
It would be nice if the text of the dimensions could be moved, without moving the dimension. Ideally this works the same as moving text in rooms (text of surface and room name).
