Total posts in this thread: 2
Previous Thread This topic has been viewed 6548 times and has 1 reply Next Thread
crevetus
Group of objects
Hello,
I like very much this program! It`s a very nice tool!
I have a question: if I select a group of objects, how can i move the group in all 3 dimensions?
I could only move the group bacward-forward or left-right but not up-down.
Thanks!
[Sep 28, 2009, 12:08:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Group of objects
Grouping/ungrouping a set of objects should be available in the coming versions to help you move, resize and rotate a group of objects.
Meanwhile, here are two workarounds:
- you may select the objects you want to elevate and choose Furniture > Modify... menu item to change their elevation, but then, of course, all the selected objects will have the same elevation,
- you may select these objects, copy paste them in a new home, export that document to OBJ format with 3D view > Export to OBJ format... menu item, import the exported OBJ file with Furniture > Import furniture... menu item, and move the imported group of objects.
[Sep 28, 2009, 4:43:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
