Re: Freezing in SH3D and Furniture Editor importing models
Thanks for the log you sent but it is not very useful unfortunately.
But the log line in the screen shot about a missing entitlement com.apple.security.automation.apple-events could be interesting if you could tell me what you were doing when this line was emitted, even if I'm not sure it's bound the crash.
Hi, I'm having the exact same issue.
Program freezes when getting to the model orientation screen. Happens for both .dae and .obj files (which work fine on my windows version).
I get the "spinning beachball" forever and that's it. No crash report, nothing. I also checked my logs, but could not find any of the messages that kutlu9 referred to above. The only messages related to SweetHome appear directly after I start the program:
Mar 21 17:54:23 C02YW0W4LVDQ com.apple.xpc.launchd[1]: Coalition Cache Hit: app<application.com.eteks.sweethome3d.SweetHome3D.54866379.54866409(501)> [571] Mar 21 17:54:23 C02YW0W4LVDQ SweetHome3D[3794]: getattrlist failed for /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver: #2: No such file or directory Mar 21 17:54:23 C02YW0W4LVDQ SweetHome3D[3794]: getattrlist failed for /Library/GPUBundles/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib: #2: No such file or directory Mar 21 17:54:23 C02YW0W4LVDQ SweetHome3D[3794]: getattrlist failed for /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib: #2: No such file or directory Mar 21 17:54:23 C02YW0W4LVDQ SweetHome3D[3794]: getattrlist failed for /System/Library/Frameworks/OpenGL.framework/Resources//GLRendererFloat.bundle/GLRendererFloat: #2: No such file or directory
I made sure the models are not located in any "managed" folder (like OneDrive).
If there's anything I can do to support debugging please let me know.
Thanks for the support!
Macbook Pro 15" 2019 2.6GHz Core i7 32GB RAM Radeon Pro 555X 4GB
SweetHome Version 6.5 OpenJDK Version 15.0.2 64 bit Java 3D Version 1.6.1 - JOGL 2.4.0-rc-20210111
Could you report if furniture import works when the 3D model doesn't contain any texture image?
United States
Re-reading your question: the question was "does furniture import works" with simple objects, and my answer should read "No, it still crashes with simple objects", that probably wasn't super clear.
