Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 78573 times and has 51 replies Next Thread
sb0373
Germany
Re: Freezing in SH3D and Furniture Editor importing models
Sorry, that is the 6.5.2 version, not 6.5.2a
[May 5, 2021, 8:09:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sb0373
Germany
Actually workaround for me is to use the jar version, import the furniture and then you can use it in the bundled version.
[May 5, 2021, 8:32:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I released yesterday a Mac App Store version 6.5.5 that should fix the issues that some of you recently encountered on Mac Intel. This version is bundled with Oracle Java 8.0_202 and JOGL 2.3.2 for x86_64 architecture and Zulu OpenJDK 15.0.2 and JOGL 2.4.0 RC 20210110 for arm64 architecture. I would have preferred to use OpenJDK 15 for both architectures but that prevents from creating a universal application which uses two different versions of JOGL (maybe I'll find another solution).
Users who still have problems under Mac M1 may run the program with Rosetta where the bug shouldn't appear (there's an option for this purpose In the Finder Information dialog box of Sweet Home 3D app).
From the different reports I got, the bug is probably a deadlock due to some changes in JOGL 2.4 required to run with recent macOS toolkit, but as I'm not the developer of this library and moreover, as I never experienced this issue myself, it might take more time to fix it and I preferred to release now this version to reduce the number of hindered users.
I developed a free version bundled with the same Java and JOGL versions too, but as it weights 30 MB more and can't be notarized, I prefer to not distribute it at the moment and in case of problems, I recommend to switch to the version 6.5.2 based on JOGL 2.3.2 (68 MB) that I released a few weeks ago. At least, users of the free version may install the version of their choice which is not the case of the Mac App Store version.
[May 19, 2021, 11:18:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
henrisson
United States
Confirming the app store version isn't crashing anymore.
Many thanks Emmanuel!
[May 24, 2021, 3:46:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
paepcke
United States
Thank you so much for this fix. I am brand new to SH3D, and was excited yesterday to discover the libraries. Yet like others I encountered the beach ball of death for the application upon importing a .dae model with what I thought was the latest version. Your fix worked.
[Jul 19, 2021, 6:20:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As this issue may still happen in version 6.6, I created a special version 6.6 based on JOGL RC 2.3.2 for the users who encountered it.
This version won't run natively under ARM processors.
[Aug 7, 2021, 9:25:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sas199
Unfortunately, almost all commands in the menu bar are disabled in this version. Therefore it makes the app rather unusable.
[Mar 13, 2022, 12:41:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Menu items are enabled according to the currently selection. For example, Modify walls menu item is enabled only if at least one wall is selected.
[Mar 13, 2022, 5:11:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Could some of you test the Beta version Sweet Home 3D 7.0 to check if this issue still happen? Thanks smile
[Jul 8, 2022, 5:36:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
qinstah
Hi Emmanuel,
I am using version 7.0 (non app store) on a Mac M1 and experience the same issue (app freezes) when importing a .obj model. I've also tried to force the app to run in rosetta mode, did not help.
My current workaround is:
1. Launch older version: SweetHome3D-6.6-macosx-jogl-2.3.2
2. Import .obj model
3. Launch current version - model can be used
Btw:I just wanted to thank you for the app, its so helpful for me right now! I absolutely appreciate the active communication and development as well!
[Jul 26, 2022, 8:42:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
