United States
Re: Freezing in SH3D and Furniture Editor importing models
Re-reading your question: the question was "does furniture import works" with simple objects, and my answer should read "No, it still crashes with simple objects", that probably wasn't super clear.
I just created another version 6.5.2 based on Java 15 and JOGL 2.3.2 available here (68 MB). It will run with Rosetta 2 with Mac M1 but as some of you have problems with Mac Intel too, it could worth a try to check if the issue you encountered comes from the change of Java or JOGL versions.
Thanks for your test. So the problem probably comes from JOGL 2.4.0 or the way to use it. Could you also try the version 6.5.2a [edit: removed link] where I made a small change (this version will run natively on Mac M1)?
Hope to read the results of the tests of other users too. Please, give some feedback because I still didn't find any way to reproduce this issue.
[Edit 1 times,
last edit by Puybaret at Aug 10, 2022, 1:53:51 PM]
