Previous Thread This topic has been viewed 3081 times and has 2 replies Next Thread
Andrey.V.
Russia
confused How can I accurately snap dimension lines to the edges of the walls?
[Feb 17, 2021, 4:50:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Denis1874
Re: How can I accurately snap dimension lines to the edges of the walls?
Hello,
normally when you draw the dimension line, you have a color change when you are perfectly aligned. If you change afterwards the wall length, you need to delete and create again the dimension line if you want to use this again.
MacMini 3GHz Intel Core i5 6 cores 64Go macOS Big Sur 12.2.1
[Feb 17, 2021, 10:40:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
There's also a faster solution: when the dimension lines creation tool is active, just place the mouse pointer along a wall side and double click to create the matching dimension line. See also this video.
[Feb 18, 2021, 8:50:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
