Re: Sweet Home 3D 6.5
Sometimes, since 6.5 beta, the pointer of the mouse jumped ! And for you ? The jump is always two-three centimeters at right.
None jump with another soft...
I too noticed this. I have to click couple of mm outside to select an item. Because of this I started zooming the plan and clicking on enlarged objects with ease.
Thanks for your feedback.
@bdfd and reddy.shyam: What beta version do you use? By "jumping", do you mean that the pointer moves by itself to another place?
@snmavronis Maybe one day I'll remove Java 3D bridge and use JOGL directly, but there are very little chances that Sweet Home 3D will be reprogrammed (again) in an other language.
Hi @Puybaret, to me I have click couple of mm away from the object to select it. I am on beta4.
Could you check if you have the same problem with the version 6.5 Beta 3?
Could you send me a video showing the bug (ideally using a demo available from File > New from demo menu item)?
@bdfd and reddy.shyam: please give more details about how to reproduce the issue you reported. I didn't experience it on my side.
