Total posts in this thread: 2
Previous Thread This topic has been viewed 2410 times and has 1 reply Next Thread
daveywavey
United State
Need help
Hello, everyone,
I would like to make a round room cutout of 180 cm on the first floor, so that one can see a sculpture in the basement.
Can someone please help me in a friendly manner?
Thanks!
What is Synthetic Voice
[Dec 5, 2020, 11:17:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Need help
STEP BY STEP EXAMPLE
- Draw a room of 8x8 meters
- In the middle of the room draw a wall 180 cms long
- Modify walls > Arc Extent > 180 degrees - This gives a semi-circular wall
- Draw a second wall from exactly the same X,Y coordinates
- Modify walls > Arc Extent > 180 degrees - This gives a prefect circle in the middle of the room
- Draw a wall from one corner to the diagonally opposing corner, this bisects room and the circle
- Give walls a thickness of 0.1 cm
- Insert two rooms - You now have two rooms with a semi-circular opening
- Delete interior walls used for construction
- You are left with a perfect hole in the floor (and a narrow diagonal slit).
example file
[Edit 1 times, last edit by hansmex at Dec 5, 2020, 2:43:06 PM]
[Dec 5, 2020, 2:09:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
