Previous Thread This topic has been viewed 19070 times and has 10 replies Next Thread
mmrak
Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta
Since the latest Update of Big Sur Beta Sweet Home 3D crashes on both my MacBook and on my iMac. I have tested both versions, 6.4.2 (from SourceForge) and 6.4.3 (just purchased from the App Store), both crash at startup, please see attached crashlog.
I was able to use Sweet Home 3D without issues since Beta 4 of Big Sur.
Any hints or workarounds? Uninstalling and reinstalling did not help.
Kind regards
Michael
[Oct 17, 2020, 9:40:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta
Please report this issue to Apple and check bug ticket #976 for workarounds.
[Oct 17, 2020, 10:58:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmrak
Hi Emmanuel,
it did so and sent the bug Reports to Apple. But as I have written above its not the 3D mode that is not working, its the program that crashes at startup. So it might be a different reason.
[Oct 18, 2020, 9:51:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
61Xray
Hi Emmanuel,
The crashlog gives the following error:
Exception Type: EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Don't know if this helps.
Regards,
Michael
[Oct 25, 2020, 5:31:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmrak
Hi, is there any progress at this issue? Would be great if this problem could be fixed.
[Oct 28, 2020, 7:40:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
From jkrief report, it looks like the problem is fixed in macOS Beta 11.0.1 20B5012d.
If you’re able to install this Beta version, can you confirm?
[Oct 29, 2020, 10:34:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lfhring
Colombia
Hi friends:
I want to confirm, the program is working well again in 11.0.1 Beta
[Oct 30, 2020, 5:34:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mmrak
HI, I can also confirm that the program works again :-)
[Nov 2, 2020, 8:57:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shabadoga
Hi all,
I'm trying to run version 6.4.2 on MacOS 11 Big Sur but i have no success. An alert says me to contact the developer to know if the app is compatible with this version of MacOS. Does anyone have the same problem?
[Nov 28, 2020, 7:21:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Wouldn’t it be because Sweet Home 3D isn’t notarized yet (see bug #951)?
[Nov 28, 2020, 8:06:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
