Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 280092 times and has 51 replies Next Thread
Re: Sweet Home 3D JS Online
Works perfectly well now, and it's really FAST!
Thank you!
[Aug 11, 2020, 5:47:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
RICHARDpatrck
bonjour,
merci pour ce pas de géant :-)
je teste l'outil online qui pourrait permettre aux élèves du collège https://martonne.net/sections.php?op=listarticles&secid=5 de continuer chez eux les modélisations commencées au collège.
Par conter je n'ai pas trouvé la modification de l'épaisseur du mur ?
merci beaucoup
Cordialement
[Nov 12, 2020, 10:28:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The wall modification dialog box (and other dialog boxes) is still missing.
But about modifying the width of walls, I had an additional idea: I would like to add another indicator in the middle of the selected wall to change it. The indicator on the right side would let the user change the arc extent like now, and a new indicator on the left side would let him change the thickness of the wall. What do you think of this idea?
[Nov 13, 2020, 5:12:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
Can we use Sweet Home 3D JS Online(not only viewer, I want to use with editor) own site ? Is it open-source. If okay. When I tried to deploy with ant, why only viewer libraries exporting
[Jun 13, 2021, 1:37:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SweetHome3DJS project is distributed under GNU General Public Licence so you can use it on your own site, as long as you respect the terms of that license, i.e. providing the source code of the modifications you may have made to the project for your needs.
Read project build.xml and you’ll see that there are other targets. I guess you look for applicationBuild target.
[Jun 13, 2021, 5:52:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
When I deploy with ant I get SweetHome3DJS-6.5.2-src\tools\JSweet\build\js\bundle.js file error (it doesn't create bundle.js file) and so I can't ant "applicationBuild" files.
[Jun 14, 2021, 3:52:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you read (and use) all the instructions in the README.TXT?
[Jun 14, 2021, 4:17:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
Yes, I did everything in the README.TXT in "Sweet Home 3D JS-6.5.2", I'm getting an error while ant.
[Jun 14, 2021, 5:26:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you install Node? What error do you exactly get (please do not copy all the log)?
[Jun 14, 2021, 5:56:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
emirhanbskc
Türkiye
Yes node is installed, when I run ant command in cmd
(BUILD FAILED
C:\Users\Emirhan\Desktop\Art²kAnd\SweetHome3DJS-6.5.2-src\build.xml:79: Warning: Could not find file C:\Users\Emirhan\Desktop\Art²kAnd\SweetHome3DJS-6.5.2-src\ tools\JSweet\build\js\bundle.js to copy.),I get the error.
[Jun 14, 2021, 6:15:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
