Re: Sweet Home 3D JS Online
I was able to compile the .war file and get it to run properly using Tomcat. It's fantastic, and incredibly fast! However I can't seem to figure out how to add additional furniture on the server side. Any guidance would be greatly appreciated.
Here are the instructions you can use to add more furniture to the Online version. First, gather the additional 3D models you want in a SH3F file with the Furniture Library Editor. Let's say you called it additionalLibrary.sh3f. Then you should use the PropertiesToJson tool included in SweetHome3DJS source code to convert .properties files to their equivalent .json files and extract 3D model and icon files: - Compile the com.eteks.sweethome3d.json.PropertiesToJson class in SweetHome3DJS root folder with the following command:
PropertiesToJson requires the 7 following arguments: 1. the folder where you stored additionalLibrary.sh3f 2. additionalLibrary.sh3f, the furniture library file to convert 3. the output folder where the .json files will be saved (if you used Tomcat to test the war file, it should be the subfolder webapps/SweetHome3DJS-7.1/lib/resources of Tomcat installation folder, but this could be also the subfolder deploy/lib/resources of SweetHome3DJS root folder). 4. additionalLibrary, the base name of the .json files 5. the folder where 3D models and icons will extracted (I recommend to use a subfolder to avoid conflicts with some other libraries stored in models) 6. the path of the 3D models and icons relative to index.jsp (the folder where 3D models can be found from the furnitureResourcesURLBase property added to index.jsp in the following instructions) 7. true (it indicates that 3D models and icons should be extracted, using false won't extract them)
For example, if you try with BlendSwap-CC-0.sh3f available here saved in SweetHome3DJS root folder and Tomcat installation folder in /Applications/apache-tomcat-9.0.41, you'll get the following command:
Once, your .json, 3D models and icons files are ready, you'll have to tell the Online version to take them into account with the two following changes: - around the end of index.jsp, add furnitureCatalogURLs and furnitureResourcesURLBase properties to JavaScript application configuration, to specify the list of furniture catalogs and the base URL for their 3D models and icons. For example, the beginning of application declaration:
var application = new SweetHome3DJSApplication( {readHomeURL: urlBase + "/readHome.jsp?home=%s",
should become:
var application = new SweetHome3DJSApplication( {furnitureCatalogURLs: [urlBase + "/lib/resources/DefaultFurnitureCatalog.json", urlBase + "/lib/resources/additionalLibrary.json"], furnitureResourcesURLBase: urlBase + "/", readHomeURL: urlBase + "/readHome.jsp?home=%s",
And if you try with BlendSwap-CC-0 library, it will become:
var application = new SweetHome3DJSApplication( {furnitureCatalogURLs: [urlBase + "/lib/resources/DefaultFurnitureCatalog.json", urlBase + "/lib/resources/BlendSwap-CC-0.json"], furnitureResourcesURLBase: urlBase + "/", readHomeURL: urlBase + "/readHome.jsp?home=%s",
(citing DefaultFurnitureCatalog.json isn't mandatory if you don't want to keep the default library).
- The additional library managed by user preferences in writeHomeEdits.jsp should be added in the declaration of serverUserPreferences instance. Therefore, the following declaration:
serverUserPreferences = new ServerUserPreferences( new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultFurnitureCatalog.json")}, serverBaseUrl, new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultTexturesCatalog.json")}, serverBaseUrl);
should become:
serverUserPreferences = new ServerUserPreferences( new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultFurnitureCatalog.json"), new URL(serverBaseUrl, "lib/resources/additionalLibrary.json")}, serverBaseUrl, new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultTexturesCatalog.json")}, serverBaseUrl);
And for BlendSwap-CC-0 library, it will become:
serverUserPreferences = new ServerUserPreferences( new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultFurnitureCatalog.json"), new URL(serverBaseUrl, "lib/resources/BlendSwap-CC-0.json")}, serverBaseUrl, new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultTexturesCatalog.json")}, serverBaseUrl);
Hope you can handle it. There are other way to generate .json files without a SH3F file, but it depends on your furniture library configuration.
I forgot to mention textures libraries. Actually, it works more or less the same with SH3T files and the two additional texturesCatalogURLs / texturesResourcesURLBase to configure application JavaScript variable in index.jsp.
For example, if you try with Contributions.sh3t available here saved in SweetHome3DJS root folder and Tomcat installation folder in /Applications/apache-tomcat-9.0.41, the following PropertiesToJson command will extract .json and texture image files :
and adding it to the textures libraries managed by user preferences in writeHomeEdits.jsp will lead to the following declaration:
serverUserPreferences = new ServerUserPreferences( new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultFurnitureCatalog.json"), new URL(serverBaseUrl, "lib/resources/BlendSwap-CC-0.json")}, serverBaseUrl, new URL [] {new URL(serverBaseUrl, "lib/resources/DefaultTexturesCatalog.json"), new URL(serverBaseUrl, "lib/resources/Contributions.json")}, serverBaseUrl);
Good luck!
I see the model file can be in zip format, I thought it is possible to add a password to zip the file to protect my proprietary model files? Do you have any suggestions?
You could grant the right to download 3D model zip files only to some identified people. If needed, the URLs in furniture libraries can be more complex URLs which call a service on the server, similarly to the service specified by readResourceURL property in application configuration on the Online version of this server. It uses the JSP page readResource.jsp?path=xxx to ensure that only a given user can access to the resources he imported.
And about protecting your model file with a password, this is not possible because JSZip doesn't support this feature yet, and even when it will be supported, Sweet Home 3D JS would need that password to decode the model files. Therefore, the password would have to be available somewhere in the configuration of Sweet Home 3D JS, making it also available to anyone wanting to find it.
Hello,
I’m happy to announce that I just released two new apps based on Sweet Home 3D JS, one for iOS and the other for Android. As explained in this article, these apps don’t require a connection to Internet to work and are able to import and export SH3D / SH3X files to share your designs on another smartphone, tablet or computer where Sweet Home 3D is installed or within a browser running Sweet Home 3D Online.
These apps are not free but remain based on the free version of Sweet Home 3D JS that I improved with the following features: - A new About dialog box was added and replaces the status bar in the Online version. - Sweet Home 3D JS now includes some new APIs to store home data using IndexedDB storage with auto recovery management. - Drag and drop support was added to images import process of the Online version. - Panes in Online version under tablets are now arranged the same way as in desktop version. - Application "sandwich" menu of the Online version is displayed in a separate div to ensure it's always visible in the toolbar. - Sort and Display column menus were added on tablets. - Combo boxes closing was fixed. - The last touched point is now used as the final point when wall, room, polyline and dimension creation tools are used and the user clicks on another tool. - Keeping the finger on a button of the 3D navigation panel on touch device now repeats rotation or zoom.
Hope you'll like this new version
[Edit 2 times,
last edit by Puybaret at Sep 8, 2023, 12:37:05 AM]
