Re: Sweet Home 3D JS Online
I did a short test on an Android tablet and it works perfect.
You probably need a larger tablet (mine is only 8 inch) to be able to do useful work. Nevertheless I was able to draw walls, a room, add some furniture and change colours.
US
I downloaded version 6.4 after using 6.0 for a while, and I like the fact that I can now move entries in the furniture list, but it only works when no sorting is being used.
I'd still like to be able to move around entries in the list when under a sorting algorithm. It would allow me to group together furniture or objects that belong to the same floor or room for easy editing end navigation.
harbinger, sorry but you shouldn’t hope to be able to reorder items in the furniture list when it’s sorted. I understand that when you use groups, reordering can’t be influenced by a sort made on levels in the furniture list, but this would work only if you move items within groups and not out of groups at the root of the list. By the way, it’s not that I don’t want to program exceptions, but those exceptions must be quite intuitive and easily understood by every user.
Xiste, this error may happen if you remove www. in front of sweethome3d.com. Could you check if it was your case? I’ll try to see how I can add the prefix automatically.
US
Actually the only reason I was sorting by level was to get all those objects together (on the same floor) and then arrange them by type, purely for finding objects more easily, and using the Group function for those items I wanted to lock together.
It seems like what we need are a few shortcuts for moving entries in the list, such as "move to top", "move to bottom", "move to home", and "move to end".
The www is not there and it seems the link cannot be edited, but that might be finger trouble on my side since I'm a bit pressed for time. I shall find the time make another try later.
I added the automatic redirection to www.sweethome3d.com for SweetHome3DJSOnline.jsp
The wall modification dialog box (and other dialog boxes) is still missing. But about modifying the width of walls, I had an additional idea: I would like to add another indicator in the middle of the selected wall to change it. The indicator on the right side would let the user change the arc extent like now, and a new indicator on the left side would let him change the thickness of the wall. What do you think of this idea?
