Re: Imported objects are transparent!
> How can I make them visible?
The easiest way with Sweet Home 3D would be to: - import the model 3D file in an empty home - export it to OBJ format with "3D view > Export to OBJ format..." - edit the MTL file generated along with OBJ file with a text editor - change the transparency line that starts with "d xxx" to "d 1" - save MTL file - import the exported OBJ file
