Previous Thread This topic has been viewed 2860 times and has 2 replies Next Thread
NemaTode
Starting with interior measurements and adding dimensions
Hi, I'm using SH3D for the first time and could use some help. All of my measurements are interior, and I'm trying to have all of the virtual walls accurate down to a 1/8". I'm running into problems adding dimensions when more than one dimension is starting at the same wall. I have keyed in the proper length of the wall, but I'm having problems lining up the walls so that the dimension measurement is the same as the wall length. How do I know when a wall is *exactly* lined up properly ? and with a dimension line?
Also, I didn't line up the "northwest" corner of the plan with the 0 coordinates on X and Y and now I really wish I had so that some of the wall measurements line up with the grid lines.
Thank you!
[Jul 20, 2020, 12:07:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Starting with interior measurements and adding dimensions
Maybe this video would help you achieve drawing your plan.
[Jul 22, 2020, 4:37:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
NemaTode
Puybaret, thanks for the reply and link.
I've learned a fair amount since I posted my question but I'm still unclear on how to precisely locate an interior wall. Specifying the length and width of walls is simple enough but what I can't seem to do is indicate that an interior wall must be, for example, 28" away from some other wall. As a hack, I've been creating dimension lines to manually measure the distance between various objects but is there not an easier way? The perimeter of my floor plan is half-filled with these manually-inserted dimension lines.
thanks.
[Jul 26, 2020, 10:20:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
