field multiPartModel; any use yet?
Hello: I´ve seen this field defined at DefaultFurnitureCatalog, but no use of it. Is there anything defined about it? There are no results on the forums, so I assume there´s nothing about it.
Thanx in advance. Alied
Re: field multiPartModel; any use yet?
The best documentation is the code itself. ;-)
If you follow the use of the multiPartModel flag step by step, you'll see that it's stored in com.eteks.sweethome3d.tools.ResourceURLContent instances and used by com.eteks.sweethome3d.io.DefaultHomeOutputStream$HomeObjectOutputStream class that handles the recording of a home. This flag tells if a resource is a multi part resource stored in a directory with other required resources. In the facts, the multiPartModel flag is set for all the OBJ files of a catalog or a home file that comes with a MTL file and texture image files, to tell HomeObjectOutputStream class that it should save an OBJ file and all the files that are in the same directory as the OBJ file. Look in SH3D and SH3F files, and you'll see that as soon as an OBJ file isn't alone, it's in a subdirectory and it's multiPartModel is true.
This was the original e-mail I sent to Emanuel:
Reading sweethome3d, came with this field: MULTI_PART_MODEL. I haven´t find any other use. I´m interested because I´m using part of your code in an application, and I need to load objects scattered on several .3ds files.
How can I take advantage of this? I was thinking of inheriting from CatalogPieceOfFurniture and create my model from a .ini file. I already have the code to load an join the objects according to corresponding points, but it would be better if support or this is already done. Even if I have to handle it on my own, if it is not already done, I could contribute my code to do so.
And this was hs answer:
As I answered to you on the forum, this flag could interest you at recording time since if you place all the 3DS files in the same sub directory and set the multiPartModel# key to true, current IO classes will record all the 3DS files in the same directory as the one referenced by ResourceURLContent. If I had to program it myself, the model# keys would reference files at a new format MYFORMAT describing how to assemble the 3DS files in the same directory as your MYFORMAT file. Then I would program a new Java 3D loader able to handle the MYFORMAT files and tell Sweet Home 3D to add the class of this loader to the supported ones with com.eteks.sweethome3d.j3d.additionalLoaderClasses system property (used in ModelManager). If you use classpath correctly, this way of doing will even avoid you to compile Sweet Home 3D main jar. ;-) See also my comments at https://sourceforge.net/tracker/?func=detail&...id=152568&atid=784668
A last thing : please post again your need on the forum, and I'll post my answer to let everyone share this idea. ;-)
