Previous Thread This topic has been viewed 5545 times and has 2 replies Next Thread
Olaf_Noehring
Feat. Req: Automatically measure all walls
Hi
I have used Roomarranger in the past. A great feature there is to automatically measure all walls - saves a lot of work.
Olaf
[May 15, 2009, 10:57:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
c_sanz
Re: Feat. Req: Automatically measure all wall
The tool "Create dimensions" has no dependence on an object, dimensions are totally free, so therefore the magnetism of these does not work on the walls.
This function is not provided in the near future.
Greeting,
Christian.
[May 16, 2009, 2:23:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mark
Re: Feat. Req: Automatically measure all walls
If "measure" means something like total length of all walls or area wouldn't it be pretty easy to make a plugin and then just run from the menu ? i.e. like volumeplugin.
Something like ....
VolumnePlugin.java
public void execute() {
float volumeInCm3 = 0;
double wallLength = 0;
double totalWallLength = 0;
StringBuffer wallDimensionsMsg = new StringBuffer();
for (Wall wall : getHome().getWalls()){
if (wall.getXStart() == wall.getXEnd()) {
wallLength = wall.getYStart() - wall.getYEnd();
} else if (wall.getYStart() == wall.getYEnd()){
wallLength = wall.getXStart() - wall.getXEnd();
} else {
wallLength = Math.sqrt(Math.pow((wall.getXEnd()-wall.getXStart()),2)
+ (Math.pow((wall.getYEnd() - wall.getYStart()),2)));
// get rid of negative values
wallLength = ((wallLength < 0 ? -wallLength : wallLength));
totalWallLength+=wallLength;
wallDimensionsMsg.append("Wall: length " + wallLength + "\n");
wallDimensionsMsg.append(String.format(" Total wall length = %.2f cm", totalWallLength));
JOptionPane.showMessageDialog(null, wallDimensionsMsg);
Output would be " Total wall length = 1455.00 cm"
Excuse me if I got the wrong end of the stick :)
ta
mark
[May 17, 2009, 11:54:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
