dorin
Romania
Re: Polylines
@1. -Install AdvancedEditing plugin; -Select the polyline; -Edit points... -New (on bottom left).
@2. To have the length I use HORIZONTAL cylinder, export to CSV then in Calc or Excel make the sum; I use this also for pipes. NOTE: the cylinder MUST be horizontal in library to keep the correct length in any position or angle.
@3. Read @1 & @2. Good luck and patience!
A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law
[Jun 18, 2020, 6:40:07 AM]
[Link]
