Total posts in this thread: 2
Previous Thread This topic has been viewed 1566 times and has 1 reply Next Thread
RuudKramers
Belgium
Wooden roof structure (How to?)
How can I make a roof structure made of beams under different angles attached to a roof that goes from approx. 45 degrees for the major part of the roof to a section of approx 30 degrees. The structure also has supporting beams under an angle of 40-45 degrees. Alltogether a complex structure I would like to make out of individual wooden beams. Suggestions?
[Jun 9, 2020, 3:19:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: Wooden roof structure (How to?)
Long, thin boxes can serve as beams. In the Modify panel you can rotate them.
For the roof, you could use walls, which you can easily draw at the angles needed. Export and import them and rotate 90 degrees.
[Jun 9, 2020, 10:26:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
