Previous Thread This topic has been viewed 21818 times and has 10 replies Next Thread
Stjepan_Brbot
How to color walls?
In SweetHome3D help there are pictures of homes with colored walls. I don't know how to color walls?
[Apr 12, 2009, 9:00:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
c_sanz
Re: How to color walls?
When you double-click a wall, a dialog box
propose to color the left side (outside) and right side (interior) of the wall.
Regards,
Christian SANZ
[Apr 13, 2009, 10:52:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Stjepan_Brbot
That's it, thanks. But how to remove coloring if one doesn't need it anymore? When you choose color you cannot remove it, just change to other color.
[May 19, 2009, 4:44:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
At this time, you can remove color only with an undo operation.
But the default color is just white with a dark grey ambiant color. If you choose a grey color, you should obtain the same effect.
[May 23, 2009, 9:01:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
galaxydancing
Hello.
I've got a problem with changing wall colors.
I tried many times double-clicking on the wall and I tried to click by right mouse button and choose "modify walls", but it doesn't work. :( Have somebody an idea, why it behaves like that?
PS - I'm sorry if I made any mistake, I hope you can understand what I mean. My English is not very good and I don't trust GoogleTranlate. ;)
[Dec 18, 2011, 11:03:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You don't give much information...
- What is the operating system of your computer? Windows, Mac, Linux?
- Which version number of SH3D are you using?
- Are you using the installed version or the webstart version?
- Which version of Java are you using?
- Does the problem occur with walls that you are drawing in a new design?
- Does the problem occur in a file you have made before, and now try to modify?
- If it's an "old" file, did you transfer it from one computer to another?
- If the problem occurs in a file, you may send it to me and I'll see if I can reproduce the problem.
These questions may help to determine the problem.
[Dec 18, 2011, 11:38:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please, install Java, display Java console, run the program with Java Web Start link and report here what is displayed in Java console.
[Dec 19, 2011, 8:41:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
galaxydancing
How many details!
1. Windows 7
2. Installed version of SH3D 3.3, but in webstart version problem occurs too.
3. Java 6
4. Problem occurs in both cases.
5. The "old" file was made on my computer.
The problem occurs in many files, so I don't think that's problem with file. :)
[Dec 19, 2011, 2:04:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ok, but what text appears in the Java console?
[Dec 19, 2011, 2:14:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
galaxydancing
The text does not appear. There simply nothing happens.
[Dec 19, 2011, 10:15:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
