Print at Sep 15, 2026, 6:38:17 AM
Posted by dorin at Dec 31, 2019, 7:56:52 PM
Rooms Information plug-in
Another YAUP (Yet Another Useless Plugin).
Version 1.0
-it's intend to replace RoomsSurface plugin;
-I've add two new column: perimeter and walls surface;
-for area and perimeter could be trusted;
-the walls surface is not totally really reliable; for very common home could be used but for other kind of homes used with care;
-at the moment I limit to compute only straight walls (including sloping), not curved walls.
-TO DO in the future: to subtract the opening; I've try already but I receive strange numbers. Maybe someone could help us.
That'is!
Also on Souce Forge
Posted by dorin at Jan 12, 2020, 11:24:47 AM
Re: Rooms Information plug-in
New version 1.1
-add calculation for round walls including sloping (thanks to hansmex )
-add support for imperial measurement
-few code modification
Possible errors:
-when You modify walls after room creation even in plan don't appear so
TO DO:
-subtract holes surfaces BUT
there are many situations when will give wrong results
e.g. superimposing doors over frame door or service hatch
-I could add a new column with this calculation or modify the current one or forget
PS: make some test file to verify the accuracy;
If You discover something wrong let me know.
Also on Source Forge
Posted by dorin at Dec 27, 2020, 3:56:35 PM
New version 1.2
It look like that:
Hope You could see the news.
Advise: Don't trust it! Verify.
BUGS:
In some cases the number of holes and walls area are not correct.
It depend of how accurate and the logic of home building.
Also on SF
Posted by YGYL at Sep 8, 2021, 7:18:42 PM
rose   Re: Rooms Information plug-in
New version 1.2
It look like that:
BUGS:
Also on SF
Very useful plug-ins,but My language is Chinese 中文-中国
In Chinese Mainland,The unit is the meter(m2) Not inches(ft2)
Posted by dorin at Sep 9, 2021, 11:54:23 AM
@YGYL
1. For other language than English or French you have to:
1.1 Extract sh3p file in a folder (in fact is a jar file);
1.2 Go to /RoomsInfo/roomsinformations/ApplicationPlugin.properties;
1.3 Copy and save as ApplicationPlugin_zh_CN.properties
1.4 Make translation and converting them to ASCII encoding;
1.5 Pack back as jar and than change the extension in sh3p.
For more information about translations read this page .
2. In my country is also used the metric system.
I've test again the plugin and if I change the unit in general preferences it change also in plugin.
So, please try again to set unit to meter, centimeter or millimeter.
Posted by YGYL at Sep 9, 2021, 5:04:32 PM
confused   Re: Rooms Information plug-in
@YGYL
I just tried, but it didn't work. Just came to tell you
It is displayed in meters only when the language is switched
Posted by dorin at Sep 10, 2021, 10:20:18 AM
@YGYL
I've verify it and You've right!
I've test with ~15 languages and appear this happen only with CN.
One possible solution is to use TW when You need this plugin.
I've see some differences between this files (LengthUnit_zh_CN.properties and LengthUnit_zh_TW.properties) and after some minor modifications appear to work.
Anyway I suspect an translation error on SH3D rather than a plugin error.
Posted by YGYL at Dec 4, 2021, 6:57:16 PM
applause   Re: Rooms Information plug-in
I found the real cause of the problem
SweetHome3D.jar
In SweetHome3D.jar inside com\eteks\sweethome3d\model\LengthUnit_zh_CN.properties
Inside should be changed to
centimerUnit=\u5398\u7c73
The original has a few extra letters in front of it
Posted by dorin at Dec 7, 2021, 11:31:25 AM
New version 1.2.1
Bug fix on units display in some languages.
Many thanks to Emmanuel who point me in the right direction.
In fact he make the hard work.
Also on SurceForge .
Posted by Puybaret at Dec 8, 2021, 2:05:13 PM
You're welcome. I'm happy this wasn't a bug in Sweet Home 3D wink
Posted by dorin at Dec 19, 2021, 4:21:23 PM
New version 1.2.2
Bug fix (I hope) in use correct units on some languages, thanks to Aleksey Voitovich.
Also on SurceForge
Posted by dorin at Apr 6, 2022, 2:37:07 PM
New version 1.5
  • Fix an error when door or window are grouped.
  • Fix a bug in CSV export.
NOTE VERY IMPORTANT:
If You don't use yet Plugin Manager from Daniel118,
don't forget to remove manually the previous versions.
This one will don't replace it automatically!
The imported csv file could be look like this sample AFTER You format it in Office.
Also on SourceForge
Posted by dorin at Dec 7, 2023, 7:02:51 PM
New version 1.6
  • Fix a bug reported by Olivier when two or more levels have the same name sad but not all have rooms.
  • Probably I've made others bugs. Test it! (with care)
Also on SourceForge
Posted by goco at Jan 8, 2024, 6:58:14 PM
This from a user in the U.S. looking for totals in Sq Ft not meters: Your "Rooms Information plug-in" is absolutely GREAT!
Thanks so much,
goco
Posted by dorin at Jan 8, 2024, 9:26:59 PM
While I'm not a native English (also not a programmer) what I have to understand?
It worked or don't?
Anyway
1. Thanks you think it works (if this is the case)
2. Knowing my self I suggest you to verify it twice before fully trust the plugin results.
3. Try to find what don't work, let me know what and (with your help) I will tray to fix it.
Finally Manny thanks for your appreciations.
Posted by dorin at Jul 1, 2024, 12:22:17 PM
New version 1.7
- name spelling correction. Probably you will have to manually delete the old version.
- calculate only walls flush with the room(s)
- added room air volume column as @Robert Veres requested.
-- uses an average of wall heights around the room
- added a gray icon if the FlatLaf Dark theme is detected (byDMA wish)
- added pre-completed translation files for all available languages
