Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Head angle |
| Print at Aug 25, 2026, 6:53:46 AM | View all posts in this thread on one page |
| Posted by Martin_Peris_Martorell at Oct 3, 2008, 1:37:00 PM |
Head angle Hello everybody, Sorry if this is not the right place to post this question. I need to 3D model a small and easy indoor environment, so I find Sweet Home 3D just perfect for the task. There is just one small detail that makes it not suitable for my task. In "Virtual visit" mode the maximum allowed "Head Angle" value is 75 degrees. And I would like to set that maximum value to 90 degrees. I guess it should be easy to modify the source code to achieve that, so I downloaded the source code but I don't know where to start. Any hint? Thank you very much in advance. Martin [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Oct 3, 2008, 4:58:00 PM |
Re: Head angle You must have a good neck ! ;-) Search "75" in com.eteks.sweethome3d.swing.PlanController class (look at http://sweethome3d.cvs.sourceforge.net/viewvc...roller.java?revision=1.75 ), and you'll guess how to change it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Martin_Peris_Martorell at Oct 13, 2008, 2:26:00 PM |
Re: Head angle Thank you very much! That solved my request ^^ |
Current timezone is GMT Aug 25, 2026, 6:53:46 AM |
