Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Issue with groupings and levels |
| Print at Sep 20, 2026, 10:57:12 AM | View all posts in this thread on one page |
| Posted by deco0224 at Dec 15, 2019, 8:40:09 AM |
Issue with groupings and levels Hi there, I have modeled my 3 story house seperated on 3 levels. Each level looks perfect with its own furniture etc. But then when group the furniture I have problems. I am grouping all the furniture on the same level together, eg all level 0 furniture is in a group called 'Level 0 Furniture and the same with the other floors. I have also grouped all the level 0 electrical together into groups etc. The problem I am facing is some of the furniture from level 0 appears on level 1. When I ungroup the furniture, it displays fine again. I have selected each piece of furniture and checked to make sure it is on the correct level. I have set up the right levels with the correct elevations and none of the furniture on level 0 is taller than the ceiling height. I have set each room up using the Add room feature and each room has a ceiling and a floor. I would greatly appreciate any help on this - thank you. |
| Posted by Mike53 at Dec 15, 2019, 7:20:08 PM |
Re: Issue with groupings and levels Check you have not included stairs in your groups, they are on 2 levels. Light fittings can also be an issue if the elevation + depth takes them above the ceiling. |
| Posted by Gildaniel at Dec 17, 2019, 7:09:39 PM |
Re: Issue with groupings and levels Try before grouping elevate your level extrimely high (10m) then, group objects and lift back High furniture can be seen and selectable through levels |
Current timezone is GMT Sep 20, 2026, 10:57:12 AM |
