Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Different floor textures in different rooms? |
| Print at Sep 6, 2026, 5:51:48 AM | |
| Posted by Per_Jonsson at Sep 8, 2008, 6:06:00 PM |
Different floor textures in different rooms? Thanks for a _great_ program! Is it possible to have different floor colors/textures in different rooms? / Per [Note: this thread was started on sourceforge.net forums] |
| Posted by pencilart at Sep 8, 2008, 7:38:00 PM |
Re: Different floor textures in different roo That would be a great addition. I would like that too. |
| Posted by Puybaret at Sep 8, 2008, 8:56:00 PM |
Re: Different floor textures in different roo It's not possible at this time. I'm working on it. Next version should allow the user to change the color/texture of each room individually, and to import additional textures. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Sep 8, 2008, 9:09:00 PM |
Re: Different floor textures in different roo I thought of a bit of a work around: Use the cube that you provided (the box in the Miscellaneous category) and just flatten it. Then apply a different color for each room that you've put it in. However, it would be a problem if the room is not square or has a "bay" area (sticks out with the walls at an angle other than 90ยบ.) |
| Posted by Puybaret at Dec 10, 2008, 1:18:00 AM |
Re: Different floor textures in different roo Rooms with their own texture or color were added in version 1.5 ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mnemix at Dec 13, 2008, 9:28:00 PM |
Re: Different floor textures in different rooms? I'm using the 1.5 version but I can't apply different textures or colors to the room's floors. Why? How can I do it? Thanks for this great software. |
| Posted by Puybaret at Dec 13, 2008, 10:02:00 PM |
Re: Different floor textures in different roo Create a room with the "Plan > Create room" for each floor you want to change, and then modify the room. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mnemix at Dec 16, 2008, 2:21:00 PM |
Re: Different floor textures in different rooms? But, when I try to modify the room, I don't obtain any menu, neither double-clicking on it, nor right button of the mousse. How can I modify the floor of each room? Any screenshot to show it to me? Thanks and congratulations for the software. |
| Posted by pencilart at Dec 16, 2008, 5:57:00 PM |
Re: Different floor textures in different roo I hope this helps! http://i64.photobucket.com/albums/h186/gymnart/SH3D_modifyroom_tut.jpg |
| Posted by mnemix at Dec 16, 2008, 8:58:00 PM |
Re: Different floor textures in different rooms? Ok, I've yet tried it, but when I right click at 2D grid the sub menu pop up, but when I select "Modify Room" doesn't happens. When I right click at 3D View I can modify the main floor (grasp, sky...), but not the room floor. What's going wrong? I'm very desperate. Thanks |
| Posted by mnemix at Dec 16, 2008, 9:08:00 PM |
Re: Different floor textures in different rooms? YEAHHHH; I have it, I have it!!! I've found a bug!!!! The problem is that I'm using SH3D in Spanish. Try to change the language and try to obtain this dialog box, can you? If I change the language to English, I can see this dialog box, but not in Spanish. I've checked it in all languages, and only fails in Spanish... I was going a little mad... Please check it and try to improve it for the next version. Thanks |
| Posted by Puybaret at Dec 16, 2008, 9:09:00 PM |
Re: Different floor textures in different roo You must select the room first, then you can modify it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Dec 16, 2008, 9:27:00 PM |
Re: Different floor textures in different roo Thank you very much for your advanced search. :-) Miserably, I found also some problems in the Brazilian version when you want to modify a piece of furniture or the page setup. I fixed the bug in the source files and probably release a new version in the coming days... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Dec 18, 2008, 12:21:00 AM |
Re: Different floor textures in different roo I released the version 1.5.1 to fix this bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 5:51:48 AM |
