Print at Aug 25, 2026, 5:14:17 AM
Posted by pjw359 at Nov 25, 2019, 1:43:54 AM
Can I superimpose one image on another?
I'd like to view a first and second image in respective levels superimposed, at the moment each image is a background image in a level but I can't see to view them together. My best work around is to superimpose the images using GIMP and then use a single combined usage ... but this is not ideal.
Posted by Puybaret at Nov 25, 2019, 11:38:19 AM
Re: Can I superimpose one image on another?
There's only one background image per level as you noticed.
You could apply an image as a texture on the top of a thin box. This tip may give you also more ideas.
Posted by DanielJ at Nov 26, 2019, 4:29:46 AM
Can we set macraces on this topic? I have a number of identical objects with different variables that will change slightly.
