Print at Sep 6, 2026, 5:51:45 AM
Posted by yves_bruant at Sep 8, 2008, 3:00:00 PM
Wall with a slope at the bottom
Is it a way to draw a wall with a slope not on its top, but at its bottom (along a staircase) ?
Posted by pencilart at Sep 8, 2008, 7:28:00 PM
Re: Wall with a slope at the bottom
I've done that.
Just choose "sloping wall" and give the ending point (or starting point) a lower number.
For example: Start: 125, End: 55 (or the reverse, depending upon how you've placed your stairs). The numbers I used were for the "Grand Staircase" model.
See this screenshot example: http://i64.photobucket.com/albums/h186/gymnart/Stairs-slopedwalls.jpg
Posted by Puybaret at Sep 9, 2008, 12:18:00 AM
If I understand correctly, it's not possible with a wall but you can do it with the right triangle object I added in 3D models import page at
http://sweethome3d.sourceforge.net/models/triangle.zip .
During its importation, rotate the triangle in such a way that its hypothenuse is below and not above.
If it's not clear enough, don't hesitate to ask more information.
Posted by yves_bruant at Sep 11, 2008, 9:47:00 AM
Thanks a lot
