Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Wall with a slope at the bottom |
| Print at Sep 6, 2026, 5:35:22 AM | View all posts in this thread on one page |
| Posted by yves_bruant at Sep 8, 2008, 3:00:00 PM |
Wall with a slope at the bottom Hi, Is it a way to draw a wall with a slope not on its top, but at its bottom (along a staircase) ? [Note: this thread was started on sourceforge.net forums] |
| Posted by pencilart at Sep 8, 2008, 7:28:00 PM |
Re: Wall with a slope at the bottom I've done that. Just choose "sloping wall" and give the ending point (or starting point) a lower number. For example: Start: 125, End: 55 (or the reverse, depending upon how you've placed your stairs). The numbers I used were for the "Grand Staircase" model. See this screenshot example: http://i64.photobucket.com/albums/h186/gymnart/Stairs-slopedwalls.jpg |
| Posted by Puybaret at Sep 9, 2008, 12:18:00 AM |
Re: Wall with a slope at the bottom If I understand correctly, it's not possible with a wall but you can do it with the right triangle object I added in 3D models import page at http://sweethome3d.sourceforge.net/models/triangle.zip . During its importation, rotate the triangle in such a way that its hypothenuse is below and not above. If it's not clear enough, don't hesitate to ask more information. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by yves_bruant at Sep 11, 2008, 9:47:00 AM |
Re: Wall with a slope at the bottom Thanks a lot |
Current timezone is GMT Sep 6, 2026, 5:35:22 AM |
