Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: How to generate a .h file with javah? |
| Print at Jul 11, 2026, 8:48:16 AM | |
| Posted by enkonyito at Nov 10, 2019, 5:18:07 PM |
How to generate a .h file with javah? In the YafarayRenderer.java file of the new plugin , there is the procedure to generate the YafarayRenderer.h file. By replacing the initial packages with that of the PhotoVideoRendering plugin, I get this error message: Error: Could not find class file for 'betaTest_plugin.YafarayRenderer'.Enko ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Nov 15, 2019, 6:38:17 PM |
Re: How to generate a .h file with javah? To generate a .h file, you have to compile first the class which contains native methods, and add the path of the compiled class to the classpath used by javah. Have a look to the comment of loadDLLs method in YafarayRenderer class to get more ideas. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Nov 16, 2019, 2:51:06 AM |
Re: How to generate a .h file with javah? Thank you Emmanuel! Based also on this documentation, I was able to generate the YafarayRenderer.h file in the plugin package. /* DO NOT EDIT THIS FILE - it is machine generated */Since I don't know JNI, generating DLLs is less obvious and I get an error in Eclipse when rendering. It's easier with the modified YafaRay rendering plugin because I kept your packages and added the necessary files and folders. ---------------------------------------- EnkoNyito |
Current timezone is GMT Jul 11, 2026, 8:48:16 AM |
