Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Resizing items with click and drag with a mouse |
| Print at Oct 6, 2026, 5:55:32 AM | View all posts in this thread on one page |
| Posted by macnab at Nov 3, 2019, 4:15:12 PM |
Resizing items with click and drag with a mouse Hi Is it just me, or does the sizing corner of a selected item only do both X and Y at the same time? One would expect the drag direction to set the resize direction, as works with move. |
| Posted by Puybaret at Nov 3, 2019, 6:04:01 PM |
Re: Resizing items with click and drag with a mouse If you want to resize along the 3 dimensions, you should press the Shift key while moving the sizing corner, and if you want to resize only along one dimension (X or Y), you should press the Ctrl key (alt / option key under macOS) while moving the sizing corner. Sorry, these two keys are actually missing in the shortcuts list. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by macnab at Nov 3, 2019, 7:48:37 PM |
Re: Resizing items with click and drag with a mouse Thanks. I got caught out because the unviewable light panel doesn't react that way. Always behaves as though the Shift key is pressed. |
Current timezone is GMT Oct 6, 2026, 5:55:32 AM |
