Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Separate texture scaling for each dimension |
| Print at Oct 9, 2026, 7:47:45 AM | View all posts in this thread on one page |
| Posted by tapani at Oct 31, 2019, 11:27:21 AM |
Separate texture scaling for each dimension Would be nice to have the texture scaling option for each dimension (x, y z) separately. Also there should be a lock for the texture aspect ratio. When I assign a texture to an object and then change the texture, it does not change in all existing objects. So instead of copying the texture to objects, a reference should be made. |
| Posted by Puybaret at Oct 31, 2019, 12:08:45 PM |
Re: Separate texture scaling for each dimension Hum, I should you should try to understand how texture coordinates work. Texture scaling can be made on 3 dimensions! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 9, 2026, 7:47:45 AM |
