Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Render gives only black images |
| Print at Sep 20, 2026, 11:28:12 PM | |
| Posted by ForlaniM at Oct 23, 2019, 2:48:36 PM |
Render gives only black images Hi all, i'm using the fere version to see how to renew my home. I'm facing a strange problem: On my PC (win 10 pro 64bit) using latest version (6.2 if i'm remembering well) every photo rendering gives black images (aerial or from view point), high or less quality. I tried on another PC (win 10 pro 32bit, a little bit older, with less RAM and i had to use version 5.2 because newer versions can't work with G41 chipset): opening the same project renders well. I can't use this PC everytime i need because it's not at my home. Any suggestion will be appreciated. |
| Posted by hansmex at Oct 23, 2019, 11:26:32 PM |
Re: Render gives only black images Hi, If you send me your file, I'll have a look at it. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by ForlaniM at Oct 29, 2019, 5:15:55 PM |
Re: Render gives only black images Sorry, i was away and i'm reading now your answer. I've solved creating the project with the "older PC" and then opening at home. So now i can work at home "on my home". thanks anyway. |
| Posted by LPQ at Nov 22, 2019, 12:54:10 PM |
Re: Render gives only black images Hi, since I installed the most recent version (6.2), I can't render again ... do you know why this is happening to me? Regards. Leandro from Argentina. |
Current timezone is GMT Sep 20, 2026, 11:28:12 PM |
