Print at Oct 6, 2026, 6:54:57 AM
Posted by MichaelN at Sep 22, 2019, 1:05:44 PM
How to design a bathroom?
I have an issue to design the walls of the bathroom.
I want different types of tiles on different areas of the room and also in different heights.
If I use a texture on the wall, the texture is in correct dimension, but just for the complete wall. And - in case of a "front wall" ( Vorbauwand) I want also a texture on the top of the wall, what is impossible.
If I use a box instead of the wall, I have the issue, that the texture of the tile is expand on the complete front of the box, not in the right dimension. For example the tile is 60x30cm, but the box ist 100x80cm, than the box shows just one tile. It works in a different ways than the textures on walls.
How do you make such a design like this
Posted by waleedfahmy at Sep 22, 2019, 5:12:01 PM
Re: How to design a bathroom?
I had the same problem that there is no separations between imported tiles so it looks as one piece and I solved editing the tile texture image in photo editing software by adding a thin border around it .
for separating two parts of a wall horizontally use baseboard with the height you want and smallest available thickness (0.001 m) and for separating vertically divide the wall into two walls .
Posted by MichaelN at Sep 22, 2019, 6:54:11 PM
The baseboard... thats a good trick! THX!
Posted by waleedfahmy at Sep 22, 2019, 9:37:18 PM
You are welcome :)
Posted by MichaelN at Sep 23, 2019, 9:40:52 PM
Too sad - it doesn't work for sloping walls
Posted by waleedfahmy at Sep 24, 2019, 2:01:34 AM
Hi Michael
it is working for sloping wall but the baseboard will be horizontal not sloping , do you mean you want the baseboard the same slope as wall ?
