Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: 6.2 Freezing when I try to Export to OBJ |
| Print at Oct 9, 2026, 9:52:10 AM | |
| Posted by 2CP at Sep 9, 2019, 3:35:03 AM |
6.2 Freezing when I try to Export to OBJ I've done many successful exports of objects to OBJ format and then imported them to my library, but now, both before and after I upgraded to 6.2, When I hit Export to OBJ I get the first window, but it freezes before even showing the contents of the default folder. I have to use Task Manager to exit from Java Binary in order to shut it down. It is happening on any floor plan, including a test one with just one object. Running Windows 7 on a Dell Latitude 6520 with 8g memory and I updated Java. Any ideas? Much appreciated! |
| Posted by hansmex at Sep 9, 2019, 10:44:14 PM |
Re: 6.2 Freezing when I try to Export to OBJ If this happens with any object you try to export, than most probably Windows is the cause of the problem. Try to roll back the last update (or even two) and than test again. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by 2CP at Sep 10, 2019, 1:53:10 AM |
Re: 6.2 Freezing when I try to Export to OBJ Thank you, Hans(?), it WAS a problem in Windows. |
Current timezone is GMT Oct 9, 2026, 9:52:10 AM |
